No integrated Graphics intel i5-9300HF (GTX 1050) (Lenovo Ideapad L340)
unreal_rj
Lenovo Ideapad L340
intel i5-9300HF
Nvidia Geforce GTX 1050
Hi Community,
Currently i have
Lenovo Ideapad L340
CPU- intel i5- 9300HF (Coffee lake) (No integrated GPU)
GPU- Nvidia GTX 1050
RAM-16 GB DDR4
SSD 512GB
Asus TUF A15
CPU- AMD Ryzen 7 6800H
GPU- AMD Radeon
GPU- Nvidia RTX 3060
RAM- 16GB DDR5
SSD 512GB
i have little bit of idea that ASUS i have can not support Hackintosh
is there any possibility to run hackintosh on lenovo? as it does not have integrated graphics
Hi Community,
Currently i have
Lenovo Ideapad L340
CPU- intel i5- 9300HF (No integrated GPU)
GPU- Nvidia GTX 1650
RAM-16 GB DDR4
SSD 512GB
Asus TUF A15
GPU- AMD Radeon
RAM- 16GB DDR5
SSD 512GB
Lenovo is definitely not supported. ASUS is but APU will not work for now.
Thanks for responding,
Update- Lenovo has coffee lake with GTX1050,
I followed your youtube tutorial for bootable usb and EFI making, i am getting error 0xE RT.GV wake failure, assistance would be great.
Trying to make ventura work,
Config.plist attached, using opencore
Is the IGPU factory disabled? If so, the GPU can work using the OCLP.
For the error, enable SetupVirtualMap and then check.
Reactions: unreal_rj
with SetupVirtualMap enabled, it did go bit further, setup is not going further than image attached below, sorry i am new and do not have much knowledge to fix it
seems like stuck at applekeystore test,
attaching EFI and hardware zip, kindly help
The Device ID for the GTX1050 is different than what macOS supports.
xmax114
