Sonoma - No audio device, alcid=XX device-id no help
GeoSt77
Dell
i5-7500T
Intel HD 630
  1. iMac Pro
I have Sonoma 14.1.1 runnin on Dell Optiplex 7050 micro PC, Intel i5-7500T, HD 630 (not UHD).
I have no audio device listed at Sonoma:
Tried Hackintool - nothing at Sound too:
Tried HWiNFO under Win10:
I see two devices? I am not sure. Someone told me to use Realtek one, first one:
DeviceInstanceId HDAUDIO\FUNC_01&VEN_10EC&DEV_0255&SUBSYS_102807A1&REV_1000\4&6EB6490&0&0001
They assume my device is Realtek ALC225 (based on DEV_0255 part). I am not sure. Is that correct?
I have AppleALC.kext aded to EFI and based on their device-id table here https://github.com/acidanthera/AppleALC/wiki/Supported-codecs :
RealtekALC225/ALC3253layout 28, 30, 33, 90
And based on instructions I need to add that layout XX id to boot-args, so I did that with all four (28, 30,33, 90), but none works.
<key>boot-args</key>
<string>-v alcid=90 watchdog=0 agdpmod=pikera dk.e1000=0 e1000=0</string>
So even with trying all layouts via boot-args - I am still no audio. Help ?
PS: Here are my DeviceProperties from config.plist, just in case:
<key>DeviceProperties</key>
<dict>
<key>Add</key>
<dict>
<dict>
<data>AADAhw==</data>
<key>device-id</key>
<data>FlkAAA==</data>
<key>framebuffer-con1-alldata</key>
<data>AQUJAAAIAACHAQAA</data>
<key>framebuffer-con1-enable</key>
<data>AQAAAA==</data>
<key>framebuffer-con2-alldata</key>
<string>&lt;02040a00 00080000 87010000></string>
<key>framebuffer-con2-enable</key>
<key>framebuffer-fbmem</key>
<data>AACQAA==</data>
<data>AAAwAQ==</data>
</dict>
</dict>
<key>Delete</key>
<dict/>
</dict>
Attached also whole config.plist.
I did add AppleALC.kext, under Lilu.kext, removed any kext adviced at AppleALC github page ...
Remove AppleALCU.kext. Attach complete PR Files.
Removed AppleALCU. No audio yet.
Tried to collect PR files, as much I can.
OC EFI folder - yes
Hackintool>PCIe Export - yes
Bootlog - yes
Extensions/kextstat - yes
I was not able to:
IOReg (Use only v2.1) - not sure if that is ioreg shell command. And not sure what version it is. Still attached ioreg > ioreg.txt
System Report>System Information>Save - I can't find where that is and how to save. Found System Report and stuck there at that window: Hardware, Network, Software ... But no System Info and Save option anywhere.
I hope attached is enought. If need will seek more infoif adviced.
OC EFI folder - yes
Bootlog - yes
I was not able to:
Seemse like you have not patched the IRQ conflicts. It's mandatory on Dell!
fierofree
