After enabling Audio, you might encounter no Audio after sleep/wake. To fix this issue, follow the steps below.
Problem Reporting
Details :
Screen shots :
- Download latest version of CodecCommander
- Extract the kext from the release folder.
- Mount your EFI Partition.
- Navigate to EFI/CLOVER/kexts/Other and place the kext.
Problem Reporting
Details :
- Audio Codec
- macOS version/CPU/GPU
- Copy of IOReg
- Method used for enabling Audio
- Installed CodecCommander.kext
- Output of (in Terminal):
sudo kextcache -i/
Screen shots :
- DPCIManager/Status
- System Information/Hardware/Audio(All available Devices)
- System Preferences/Sound/Output
- System Preferences/Sound/Input
- Compress EFI/Clover, exclude the themes folder Do not include complete EFI folder.
