INFO Common Device Properties for macOS [Clover/OpenCore]
Kexts Specific
WhateverGreen
Global
Device PropertiesDescription
enable-hdmi20
  • Enables CoreDisplayFixup functionality via WhateverGreen.kext.
  • Enables HDMI 2.0 patches on IGPU and dGPU.
  • Patches CheckTimingWithRange in CoreDisplay.framework to skip validation of the pixel clock.
  • This prevents a black screen for HDMI in UHD resolution with 60FPS or more.
  • Required for Laptops and OEM systems with 4K/UHD/QHD Displays.
  • If you get "gIOScreenLockState3 error", you'll need to use this property.
  • Does not work on macOS Big Sur (11.x) and later.
rebuild-device-tree
  • Forces device renaming on Apple FW.
no-gfx-spoof
  • Avoids forcing of original device-id value from PCI I/O
  • Useful for Graphics spoofs. See Spoofing Graphics for more information.
  • Only valid for GPUs. No other type of device spoof is supported using this property.
Board-id
agdpmod
  • Disables board-id check.
  • Fixes black screen
agdpmod
  • Replaces board-id with board-ix.
  • Fixes black screen when macOS finishes loading.
  • Required for Navi-based AMD GPU.
agdpmod
  • Disables AGDP patches (vit9696,pikera value is implicit default for external GPUs)
GPU Switching
disable-gpu
  • Disables all external GPUs (NVIDIA and AMD). Mainly required on Dual GPU Laptops.
  • Users who have patched ACPI and dGPU is disabled via DSDT and SSDT, you don't need to use this boot arg.
  • This boot arg is a temporary solution. It's recommended to patch your DSDT and related SSDTs to disable the discrete Graphics for a better power management and improved battery performance.
disable-gpu
  • Disables internal GPU
  • Requires property on IGPU.
switch-to-external-gpu
  • Disables internal GPU when external GPU is installed.
NVIDIA Graphics
disable-metal
  • Disables metal support on NVIDIA GPUs
force-compat
  • Ignores compatibility check in NVDAStartupWeb
disable-gfx-submit
  • Disables interface stuttering fix on 10.13
Intel Graphics
AAPL,snb-platform-id
  • Injects a dedicated framebuffer identifier into IGPU
  • Only for Sandy Bridge.
AAPL,ig-platform-id
  • Only for Ivy Bridge and Later.
disable-metal
  • Disables Metal support on IGPU.
enable-metalto force enable Metal support on Intel for offline rendering.
igfxpavpto force enable PAVP output
igfxfw
  • Forces loading of Apple GuC firmware
  • Requires 300 series chipset.
disable-hdmi-patches
  • Disables DP to HDMI conversion patches for digital sound.
enable-dpcd-max-link-rate-fix
  • Fixes invalid maximum link rate
  • This property on IGPU can fix the invalid link rate otherwise a kernel panic can occur due to a division-by-zero.
  • Usually required by Laptops with a Sharp Display and more refresh rate.
enable-hdmi-dividers-fix
  • Fixes the infinite loop when establishing an HDMI connection with a higher pixel clock.
  • For example, connecting to a 2K/4K display with HDMI 1.4, otherwise, the system just hangs and the built-in display will remain black when plugging the HDMI cable.
enable-lspcon-support
  • Enables LSPCPN driver support to enable DisplayPort to HDMI 2.0 output on IGPU.
  • LSPCON driver is only applicable for Laptops with HDMI 2.0 routed to IGPU.
  • If your HDMI 2.0 is routed to IGPU and is working properly right now, you don't need to enable this driver, as your onboard LSPCON might have been already configured in the firmware to work in PCON mode.
  • This property can also provide HDR signaling over HDMI.
disable-telemetry-loadDisables iGPU telemetry loading that may cause a freeze during startup on certain laptops such as Chromebooks
disable-agdc
  • Disables AGDC
complete-modesetto force complete modeset on Skylake or Apple firmwares.
complete-modeset-framebuffersto specify indices of connectors for which complete modeset must be enforced. Each index is a byte in a 64-bit word; for example, value 0x010203 specifies connectors 1, 2, 3. If a connector is not in the list, the driver's logic is used to determine whether complete modeset is needed. Pass -1 to disable.
force-online
  • Forces online status on all displays.
  • Resolves display after wake on CFL and later.
force-online-framebufferto specify indices of connectors for which online status is enforced. Format is similar to igfxfcmsfbs
rps-control
  • Enables RPS control patch (improves IGPU performance)
enable-cdclk-frequency-fix
  • Enables all valid Core Display Clock (CDCLK) frequencies on ICL platforms.
  • This property on IGPU can be used to prevent a kernel due to an unsupported CD clock decimal frequency.
  • Usually required by Laptops with lower clock frequency values such as 172.8MHz.
enable-dvmt-calc-fix
  • Fixes Kernel Panic due to incorrect amount of DVMT pre-allocated memory.
  • Usually required by Laptops where the BIOS is locked and the variables cannot be modified using Shell.
enable-max-pixel-clock-override
max-pixel-clock-frequency
  • Fixes HDMI in UHD resolution with 60FPS
  • This property on IGPU can be used to raise the max pixel clock limit (as an alternative to patching CoreDisplay.framework).
  • Prevents black screen on 4K/UHD/QHD Displays @60Hz and HDMI 2.0 in UHD resolution with 60Hz or more.
  • Requires Invalid Maximum Link rate for Laptop Displays with more than 60Hz.
  • This property can be used for 4K@60Hz over HDMI 2.0.
  • Required for Laptops and OEM systems with 4K/UHD/QHD Displays @60Hz.
  • If you get "gIOScreenLockState3" when booting, you'll need to use this property.
enable-backlight-smoother
  • Make brightness transitions smoother on IVB+ platforms
enable-dbuf-early-optimizer
  • Fixes garbled display on the built-in screen on Ice Lake platforms.
Backlight
applbkl
  • Disables AppleBacklight.kext patches for IGPU
  • Requires this property on IGPU.
applbkl
  • Enables PWM backlight control of AMD Radeon RX 5000 series graphic cards
AppleALC
alc-layout-id
  • Sets Layout ID for AppleALC.
  • Only relevant for Apple hardware.
layout-id
  • Relevant for both Apple and non-Apple hardware.
alc-verbs
  • Enables alc-verb support.
alc-delay
  • Adds delay in AppleHDAController.
  • Useful where the hardware isn't initialized in time for AppleHDAController which results in no Audio output.
  • Must not exceed 3000ms.
external-audio
  • Disables Audio patching on external Audio devices.
alctcsel
  • Fixes Audio on macOS after rebooting from Windows.
AirPortBrcmFixup
brcmfx-country=XX
  • Changes the country code to XX (US, CN, #a, ...)
  • Can be injected via DSDT or Properties → DeviceProperties in bootloader
brcmfx-aspm
  • Overrides value used for pci-aspm-default
  • Possible values for brcmfx-aspm (and pci-aspm-default):
    • 0 disables ASPM
    • kIOPCIExpressASPML0s = 0x00000001,
    • kIOPCIExpressASPML1 = 0x00000002,
    • kIOPCIExpressCommonClk = 0x00000040,
    • kIOPCIExpressClkReq = 0x00000100
brcmfx-driver=0|1|2|3Enables only one kext for loading
0 - AirPortBrcmNIC-MFG,
1 - AirPortBrcm4360,
2 - AirPortBrcmNIC,
3 - AirPortBrcm4331,
IntelMausi
Device PropertyDescription
mausi-force-wol
  • Froce enables Wake on LAN functionality for Intel Ethernet for testing purposes.
  • Required for misconfigured hardware.
  • Requires IntelMausi.kext.
VoodooI2C
force-polling
  • Force enable polling mode for specific I2C Controller.
  • Required where APIC interrupt is unavailable.
Reactions: trus0und
Doud
