It Unraid hypervisor(ryzen7 2700, 16Gb RAM, GTX 1060 6 Gb + GT 710) with Monterey, BugSur VM. GPU Passthrough. I don't know what other information might be needed.
In that case, try with a clean install with GTX 1060 passthrough. Also, what's the brand for the GTX 1060?
I try clean install with passthrough and hdmi cable. It don't help. It 1060 6 GB Palit Jetstream( device id 0x1c03).
Today i try it Opencore.
Are you loading the VBIOS? If not, that's the issue.
Also, you'll need to disconnect the console so that the monitor can take place with the target GPU.
Yes. I saving my vbios and use it. Test it vbios on windows VM.
You mean VNC console ? Don't use it. VM use only GPU.
It xml VM and screen.
  • vm.txt
    vm.txt
hi! please answer - will this method work for macbook pro 15 (late 2013)
video cards on board:
Intel Iris Pro
NVIDIA GeForce GT 750M (if i am not wrong this is gk107)
Another user has the same issue. He has a similar setup to yours. See the thread:
As stated in the thread, we're working on it and we'll update the thread or post a guide soon as soon as it is resolved.
Can I install nvidia GTX 1060 6gb with your method
Roberto Sales
