hello, i have a nvidia GTX 1080 and i followed every step of this guide, but after restart i see a black screen...i'm currently on ventura but it resulted the same on monterey
No PR Files attached.
Hi
I followed every step carefully in the first post.
1. I could successfully install Big Sur 11.7.10.
2: I could not install my GPU, which is a GTX 1080 Ti, on Monterey 12.6.9 (after OCLP and restart, I had black screen).
3: I could not install my GPU, which is a GTX 1080 Ti, on Ventura 13.5.2 (after OCLP and restart, I had black screen).
Please guide me.
Hi
Please guide me.
Thanks it worked
Now how can I enable monitor speakers using nivdia HDMI/DP?
Thanks it worked
There is an issue with Pascal GPUs for HDMI/DP Audio. Try an HDMI/DP Adapter.
Hello.
I try Monterey 16.4; 16.6.7 + OCLP + GT 710 = it working for me.
But i need GTX 1060 6 Gb. I try 16.4; 16.6.7 Monterey + OCLP + GTX 1060 6 GB = patch success installed. MacOS starts, but system does not see GPU (2 Mb Graphics and scale 800*600)
Hello.
Your profile indicates you have an AMD Ryzen system. However, the EFI you attached indicates that you have an Intel system. Before fixing anything else, you should have a proper EFI.
Because it VM. Processor emulated for OS
wojko
