It's normal. You'll need to patch the connectors.
I thought that's what framebuffer-conX-enable, framebuffer-conX-type and framebuffer-patch-enable did. I just reread that section. Did I miss something?
If you have patched the Framebuffers, provide the PR Files to check further.
I worked on it some more. I think I have HDMI and DP1 (con0 and con1) respectively working and working correctly. Not sure why DP2 isn't working but I don't really need it. Thanks for the help! I'm sure I'll have more questions on this and other things as I work with it more. I got 1 and 2 and putting everything in a zip but in 3 I'm not sure what you're looking from IOReg. Hackintool down is pretty clear. I'm attaching all that as well, if you see something wrong and or why con2 isn't working. Screen Shot 2023-05-02 at 3.47.51 PM.jpg
I also figured out why on the 7040 I could not access any links etc on this site. There's a random "X" at the top of the page, when hovering over it gives no info but if I click it I can then access everything like links and posting etc. Not sure why it is there but it is and it isn't on my MBP with Monterey.
I worked on it some more. I think I have HDMI and DP1 (con0 and con1) respectively working and working correctly. Not sure why DP2 isn't working but I don't really need it. Thanks for the help! I'm sure I'll have more questions on this and other things as I work with it more. I got 1 and 2 and putting everything in a zip but in 3 I'm not sure what you're looking from IOReg. Hackintool down is pretty clear. I'm attaching all that as well, if you see something wrong and or why con2 isn't working. View attachment 5757
Incomplete PR Files attached.
- IOReg is missing.
- Product display output picture is missing.
In addition, the configuration is not as per the guide. A lot of problems are expected due to that.
See this thread:
- IOReg is missing.
I don't understand what you're looking for from IOReg. I screen capped the instructions and it just says IOReg with no explanation. I fixed the SMBIOS to 18,1. That was the only error I saw. Did I miss something else?
Updated EFI, screen shot of About this Mac and Display info and IOReg. Looking at IOReg AppleIntelFramebuffer@0 and @1 are very similar in output but @2 is quite different.
Provide a picture of the Ports of the system.
fierofree
