SOLVED Stuck in installation process
kapomphi
ROG Strix SCAR 17 G733
Ryzen 9 5900HX
with Radeon Graphics and NVIDIA GeForce RTX 3070 Mobile
I don't know where I did wrong, I followed this video.
Why you have enabled ProtectMemoryRegions and FixupAppleEfiImages? Shouldn't be required for your hardware.
You should consider removing the empty Device path in Device Properties.
If your BIOS has 4G Decoding options, remove npci flag.
Regarding the error, add AWAC or RTC and then check.
Thank you so much! Your advice fixed the issue perfectly.
Snowson
