Reboots during format in disk utility and installation process on a razer blade 14
TheChronic
Razer blade 14
Ryzen 9 6900hx
Radeon 680m
Hardware: CPU: ryzen 9 6900hx iGPU: Radeon 680m 1tb nvme 16gb ram ddr5 OS: Ventura Wifi works
I am 95 percent there. I have seen several post with a successful installation on a razer blade 14 with the same hardware. I mapped my usb ports before attempting to install macOS. I am able to boot to the installer just fine but while I’m trying to format my disk or actually installing macOS on the drive, it will reboot. I noticed around the 10-13 minute mark is when it reboots while installing. Any ideas on what could be the issue? Thanks in advance.
It could be either your Drive or the NVRAM issue. It could be also possible that your EFI is not up to the mark.
fierofree
