Yeah, correct. I didn't pay attention. Move the kexts from 10.14 to Others folder. Delete the rest. From the drivers directory, delete BIOS folder. Attach a screenshot for the TB setting in BIOS. Also, change the config.plist from the above link.Nope, is in the "others" folder
Yes.The config.plist linked by you is the basic one?
Yeah, correct.I compared it with mine and is very closer.
Yes, it's better with TB.You also said to change the SMBIOS to iMacPro1,1
Looks good.And this is the pic with my thunderbolt settings.
Yes.
Yeah, correct.
Looks good.
NVMe is great.Thanks for the reply. Tomorrow I'll replace my SSD with NVMe M.2 and I'm thinking to reinstall the O.S.
This is a normal issue and has no affect. The error is due to the Hotplug drivers.Anyway, I'm still getting `I2cWR Device Error` in the UEFI logo screen. Any solution for this? What could be the cause? Thanks.
For basic compiling, you need two things only. iasl in your Usr/bin and MaciASL in Applications folder.So my problem was originally that I could not open the SSDT-Z390-TB3HP.aml so I convirted it to a .dsl so I could open it
( iasl -da -dl )
No IOReg attached. No kextcache output attached.I changed the path like it said to RP17
The drivers are missing from your Clover folder. Moreover, it's not as per the installation guide.I am stumped. for reference my thunderbolt 3 works but it is not hot pluggable
