How to Enable Thunderbolt 3 Hotplug on macOS [Clover/OpenCore]
An EliteMacx86 Exclusive Guide - This guide covers the implementation of Thunderbolt™ 3 Hotplug on macOS for single and multiple Thunderbolt 3 Cards.
An EliteMacx86 Exclusive Guide - In our previous post, we covered a guide about the implementation of Thunderbolt on macOS. This guide covers the implementation of Thunderbolt 3 Hotplug. By following this guide, you'll be able to use HotPlug function on macOS for your Thunderbolt 3.
You can read about the implementation of Thunderbolt 3 here:
www.elitemacx86.com
For more information on Thunderbolt 4 Hotplug, refer to the guide linked below.
www.elitemacx86.com
Implementation of Hotplug with Thunderbolt has been always a major issue with macOS. But Thanks to users like KGP who have been able to implement it on the hardware. The reason for the not working of Hotplug with the Thunderbolt is due to the working style of thunderbolt on both the platform i.e. Windows and Mac. On Windows hardware, the working of Thunderbolt is different as compared to a real Macintosh.
Before getting into it, let's get to know about the working of ThunderBolt on Mac and Windows hardware which will help you to understand the working of Hotplug.
On Windows hardware, the Thunderbolt is only powered up when any Thunderbolt compatible Device is connected. The device triggers the thunderbolt to function and turns on the power to the connected device. Once, it's disconnected, the power to the port is also turned off.
On the other hand, on Mac, it's not the same. On Mac, the Thunderbolt is always on until the system is turned off. When any device is connected to the Thunderbolt port, the Device automatically connects to the thunderbolt and this is the reason the hotplug basically works. The Thunderbolt is always active as it keeps drawing the power.
On the Hackintosh, it's a little bit different or you can say, it's mixed. The thunderbolt will function only if the device is connected before booting to macOS i.e preboot mode. If you disconnect it, the device no longer functions and you need to restart the system again. Hence, the system is not capable of Hotplug.
But by using this guide, you would be able to implement Hotplug.
USB Type-C® and Thunderbolt™ 3
With the introduction of Thunderbolt™ technology back in 2010, Thunderbolt 1 and 2 used the "mDP" connector type to connect. Fast forward to 2015, since the release of Thunderbolt 3, it uses the new "Type-C" connector as per the new industry standards. While it was easy to differentiate between Thunderbolt 1 and 2, it is a bit difficult for users who are new to this technology, to understand the difference between a USB Type-C and Thunderbolt 3 as both of these shares the same "Type-C" connector. Nonetheless, this is one of the most common questions we hear from users regarding the difference between USB-C and Thunderbolt 3.
One of the most common questions we hear from users is regarding the difference between USB-C and Thunderbolt 3.
USB Type-C, or USB-C, is a specification for connectors and cables.
However, both, USB Type-C and Thunderbolt uses the same "Type-C" connector type to connect. Despite using the same "Type-C" connector type, it internally differs. When you connect a Thunderbolt Device on a system running macOS/OS X, it communicates with the NHI Driver and will connect to the Thunderbolt Bus (DSB1 and DSB4 ports) which is capable of delivering up to a maximum speed of 40Gb/s. Whereas, connecting a Type-C Device to the Thunderbolt Ports will communicate with the XHC Driver and fall back to the XHC Bus (typically SSP1 and SSP2 ports) instead of utilizing the Thunderbolt Bus and can deliver upto a maximum speed of 10Gb/s. If the connected Type-C Device is a USB 2.0 Device (such as iPhone, or iPad), it will communicate with Intel's "built-in" XHC Driver and fall back to the Intel XHC Bus (typically two of the HSXX ports) and can deliver upto a maximum speed of 480Mb/s respectively. See Thunderbolt Connection Modes for more information.
While some Dock (such as RazerBlade ) and Storage SSDs (such as Samsung T7) may use Type-C interface, they may not be actual Thunderbolt Devices (although Thunderbolt Compatible) and all such Devices will use the XHC Bus instead of the Thunderbolt Bus. A Thunderbolt Device will always have a discrete Thunderbolt Chip (Thunderbolt 1/Thunderbolt 2/Thunderbolt 3 or even Thunderbolt 4) on its board which communicates with the system's Thunderbolt Chip (either Onboard or AIC) and a connection is established.
In addition, there can be several other Devices that uses Type-C connector to connect but are not actually even Type-C i.e not capable of delivering Higher Speeds. The Type-C is capable of delivering up to a maximum speed of 5Gb/s (USB 3.1 Gen1) and 10Gb/s (USB 3.1 Gen2 and USB 3.2 Gen2) respectively. However, these devices (such as Audio Interface, Card Reader, iPhone or iPad) will just have the Type-C connector but still use the USB 2.0 Bus, which will fallback to the Intel's Onboard or "built-in" XHC Bus (typically HSXX ports) with a maximum speed of 480Mb/s. This means, when you connect these devices, instead of connecting to the XHC Bus (SSP1 and SSP2 Ports) on Thunderbolt Controller, it will route to Intel XHC Bus and will utilize the (HSXX) port.
With Thunderbolt 3 having dynamic detection of the capabilities of the cables and devices that are plugged in, there are several modes that can be detected and activated. This allows connecting devices with different capabilities, without the need for any additional configuration as the switching between operating modes takes place automatically and not limiting it to a particular device capability. This not only gives the ability to connect different devices with different capabilities but also does not requires the user to change the system for each of the devices to support or vice-versa.
When devices with different capabilities are connected, the connection will only support the lowest common data rate. For example, you can plug a USB 3.2 cable into a Thunderbolt™ 3 port, and the port will negotiate data, power, and video signal capabilities with the connected device at a USB 3.2 level. Depending on the device connected, the protocol will negotiate what operating mode to enter and the function to deliver. This detection happens automatically based on the device protocol and is achieved by a physical interface (PHY) layer that can dynamically switch its operating mode to drive either:
– USB 2.0, 3.0, and 3.1
– DisplayPort 1.1 and 1.2a
– Thunderbolt at 20 and 40 Gbps
USB Only Mode
If a USB device is plugged in, a USB host controller inside the Thunderbolt 3 enabled system is activated, and the Thunderbolt 3 silicon PHY drives USB (2.0, 3.0, or 3.1) signals to the USB-C port. In this mode, a Thunderbolt 3 port behaves exactly like a typical USB-C 3.1 enabled connector.
DisplayPort Only Mode
If a DisplayPort display or adapter is plugged in, the Thunderbolt 3 enabled system will detect this, and switch the pins driving the USB-C connector to the DisplayPort alternate mode. Thunderbolt 3 silicon will then act as a router to send raw DisplayPort traffic from the graphics engine within the system out over the USB-C connector pins and pass that DisplayPort link directly to the display or adapter. In this mode, a Thunderbolt 3 enabled USB-C port will support a single four lane (4 x 5.4 Gbps, or HBR2) link of DisplayPort. These four links run across the two pairs of high-speed wires in the USB-C connector and cable. This kind of DisplayPort link can support a single, uncompressed display, at 4K resolution at 60 Hz.
DisplayPort and USB Mulit-Function Mode
In this alternate mode of operation, one of the high-speed connector pin pairs of signals will be dedicated to DisplayPort (now 2 lanes at 5.4 Gbps) and one to USB 3.1 This allows for a basic connectivity for data and display devices such as docking stations or data and display dongles. With two lanes of DisplayPort 1.2a, resolutions Quad HD (QHD) can be achieved, or 2560 x1600 at 60 Hz.
Thunderbolt 3 Mode
If a cable and device supporting Thunderbolt are plugged in, the Thunderbolt silicon activates its highest capability mode and configures four high-speed links at either 10 Gbps or 20 Gbps (depending on cable and device support) to support the Thunderbolt transport. This provides bidirectional data rates of 20 or 40 Gbps (Figure 4 illustrates the 40 Gbps case). Additionally, to fill this Thunderbolt link, the silicon extracts and routes up to 4 lanes of PCI Express Gen 3 (4 x 8 Gbps) and up to two full (4 lanes) links of DisplayPort out over the Thunderbolt cable and connector to the device(s) attached downstream from the host system. The first device in the Thunderbolt link has a few options of how it can use this underlying PCI Express and DisplayPort traffic:
• Consume the data from PCI Express by connecting it to PCI Express enabled devices such as networking, storage, cameras, DSP or FPGA adapters, or perhaps some new custom product
• Consume the DisplayPort links by exposing them to a display panel, or a display connector(s)
• Pass the unused PCI Express or DisplayPort data capabilities down to another Thunderbolt device(s) via a second, daisy-chained Thunderbolt 3 port
• Some or all of the above
If the Thunderbolt device has two Thunderbolt ports, the dynamic mode configuration described above will be configured on the downstream or second port of the device when another cable and device are plugged into it. Each mode will still be supported on this downstream connector, and data and display traffic will be provided as demanded to that downstream port. If each consecutive device is a Thunderbolt device, up to 6 devices in a chain can be supported. At any time if a USB or DisplayPort device is plugged directly into the USB-C connector downstream from any device, then the Thunderbolt daisy chain is terminated at that point.
Thunderbolt Networking Mode
An additional, powerful capability of Thunderbolt also allows the connection of two or more hosts directly (or on separate ends of a Thunderbolt chain) via Thunderbolt. In this case, Thunderbolt has software which creates an IP networking link between these systems (see Figure 5). This networking mode allows for the Thunderbolt interface to act as a virtual Ethernet adapter and transfer traffic over the PCI Express interface the Thunderbolt silicon has in each host system.
Power Delivery and Charging
In each of the modes listed above, the Thunderbolt 3 system (if designed to support this by the system manufacturer) can also request to charge over the connector from a device or adapter designed for delivering power to the system, up to 100 W, via the USB-PD specification. In this way, it is possible for the Thunderbolt 3 enabled USB-C connector to support charging, display, data, or all of them at the same time in various configurations. Separately, but related, every USB-C port enabled with Thunderbolt 3 supports the basic USB 2.0 and USB 3.0/3.1 power delivery modes (power sent from the system to a device). In addition to this, Thunderbolt 3 provides the ability of the host system to send 15 W of power on at least one port if a Thunderbolt 3 device that requires bus power is connected (see Figure 6).1 This power delivery allows Thunderbolt devices to support additional performance and capabilities given this extra power. Also, just like a two port Thunderbolt device supports the same capabilities on its downstream port as the Thunderbolt host, this also holds true for power delivery.
See Power Delivery for more information.
Power Delivery
USB Power Delivery (USB PD) is a fast-charging technology based on the USB-C standard. The USB Power Delivery (USB PD) Specification enables the maximum functionality of USB by providing more flexible power delivery along with data over a single cable. This specification is for handling higher power and allows a range of devices to charge quickly over a USB connection. It operates by facilitating a conversation between two devices to negotiate a power contract so they can determine how much power can be pulled from the charger or a particular source. Power Delivery starts at the 5V setting and is configurable up to 20V. Certain Apple® and Android smartphones/tablets and various Laptop manufacturers support this technology, which provides much higher performance than standard charging methods.
Announced in 2021, the USB PD Revision 3.1 specification is a major update to enable delivering up to 240W of power over a full-featured USB Type-C® cable and connector, which is enough to charge Laptops and other devices that require more power than USB-C alone can supply. This specification was created by the USB-IF in response to requests from laptop manufacturers for a connector that could deliver more power. Prior to this update, USB PD was limited to 100W using a solution based on 20V using USB Type-C cables rated at 5A. The USB Type-C specification has also been updated to Release 2.1 to define 240W cable requirements, and with the updated USB PD protocol and power supply definition, this extends the applicability of USB power delivery to a large number of applications where 100W wasn't adequate.
The USB-C PD standard is compatible with the USB4 and USB Power Delivery 3.1 specifications. The USB-C PD specification defines how devices can use the USB-C connector to supply power and how these devices are identified and managed. It defines what the pins in the connector do and how they can be used to provide power at various voltages and currents.
Depending on the system you have, either (PC/Workstation/Server or a Laptop), the Power Delivery Spec may vary and can range between
The AIC (Add-In-Cards) can offer up to
However, depending on the board design, the Power Delivery Spec can differ. For example, the Gigabyte GC-Alpine Ridge v1.0 and v2.0 (featuring JHL6540 - Thunderbolt 3) supports PD2.0 Standard and offers up to 5V/3A (15W) and 12V/3A (36W) Power Delivery Spec. Whereas, the Gigabyte GC-Titan Ridge v1.0 and v2.0 (featuring JHL7540 - Thunderbolt 3) supports PD3.0 Standard, with Port 1 offering up to 5V/3A (15W), 9V/3A (27W), 15V/3A (45W), 20V/5A (100W) Power Delivery Spec and Port 2 offering up to 5V/3A (15W), 9V/3A (27W) Power Delivery Spec.
The Gigabyte GC-Maple Ridge v1.0 (featuring JHL8540 - Thunderbolt 4) also supports PD3.0 Standard, with Port 1 offering up to 5V/3A (15W), 9V/3A(27W), 15V/3A (45W), 19V/5A(95W) Power Delivery Spec and Port 2 offering upto 5V/3A (15W), 9V/3A (27W) Power Delivery Spec respectively.
Similarly, ASUS THUNDERBOLTEX 3 (featuring JHL6540 - Thunderbolt 3) also supports PD2.0 Standard and offers up to 12V/3A (36W) Power Delivery Spec. Whereas, the ASUS THUNDERBOLTEX 3-TR (featuring JHL7540 - Thunderbolt 3) and ASUS THUNDERBOLTEX 4 (featuring JHL8540 - Thunderbolt 4), both support PD3.0 Standard, with Port 1 offering up to 20V/5A (100W) Power Delivery Spec and Port 2 offering up to 9V/3A (27W) Power Delivery Spec respectively.
Coming down the AIC line, the ASRock Thunderbolt 3 AIC (featuring JHL6540 - Thunderbolt 3) and ASRock Thunderbolt 3 AIC R2.0 (featuring JHL6540 - Thunderbolt 3), both support PD2.0 Standard and offer up to 12V/3A
Looking at the Data Sheet of built-in Thunderbolt Chip, certain Desktop Motherboards with an onboard Thunderbolt Chip can offer up to 9V/3A (27W) Power Delivery Spec. Whereas, this can be way more limited for Laptops (such as Dell XPS 9560/9570) offering up to 5V/3A (15W) Power Delivery Spec.
Thunderbolt Capabilities
Thunderbolt Display
Unlike several other features Thunderbolt offers, the Thunderbolt 3 is also capable of displaying output via the Thunderbolt Type-C Ports and supports up to two external displays, ranging between 2K, 4K, 5K, and 8K display resolutions, and upto 240Hz Refresh rate.
As Thunderbolt itself doesn't have any kind of GPU, but it is capable of video signal passthrough and therefore, to get a display via Thunderbolt Port, you must connect a DisplayPort Cable from your GPU to the Thunderbolt "DP IN" ports. Without this setup, connecting any Display Device (such as Thunderbolt or a Type-C monitor) to the Thunderbolt Port will not have any display and will result in a black screen due to no video signals.
For Add-In Cards (AIC) Thunderbolt, it contains a "Mini DisplayPort In" (mDP) Port. As the name suggests, it's the port where your GPU signals goes in. Depending on the Thunderbolt specification, board design, and manufacturer's decision, it can be either "1xDP IN" or "2xDP IN" Port(s).
For Motherboards and systems with Onboard Thunderbolt Chip, it has a dedicated "DP IN" Port, usually located at the rear I/O panel of the system, and depending on the Thunderbolt specification, board design, and manufacturer's decision, the given DP IN Port can be either a single port that will passthrough signals to both the Thunderbolt Ports or specifically two dedicated "DP IN" Ports for each of the Thunderbolt Ports having individual video signals and individual controls.
For AIO, NUC, and Laptop computers, there is an internal routing of video signals (either from the IGPU or dGPU or both) to the Thunderbolt Chip and requires no additional configuration, other than a few BIOS Settings.
In addition, it's worth noting that Certain Laptops tend to route the video signals from the dGPU to the Thunderbolt Ports and as the dGPU isn't supported on macOS (in a muxless configuration) and needs to be disabled, you cannot drive a display via Thunderbolt Ports. This is one of the limitation unlike several other limitations on non-Apple computers running macOS/OS X. Such configuration can be often seen on certain high-end Laptops with powerful dGPU (such as RTX3060), where all the external video ports (including HDMI and mDP) are tied to the dGPU instead of IGPU and only a very few selected Laptop models (such as Dell Precision 5750) provide the option to switch between IGPU and dGPU signals for the external Ports such as HDMI, mDP, and Thunderbolt Ports. See Disabling dGPU on Laptops for more information.
Target Display Mode
Another exciting feature from Apple for its Mac lineup. Target Display mode is a feature available with certain older Mac models.
Display Conversion Support
Although, Thunderbolt's video component is a standard DisplayPort signal, but can be converted to any format that DisplayPort can be converted to. This allows connecting HDMI, DVI, and VGA displays via converters or via a Dock.
Generally, this is useful for most of the users involved in content creation (such as Music or Video Production) and helps users to maximize their productivity, reduces cable management, and gives a tidier workspace by consolidating all accessories into a single connection.
However, at any time, if a USB or DisplayPort device is plugged directly into the USB-C connector downstream from any device, then the Thunderbolt Daisy Chain is terminated at that particular point.
While Thunderbolt supports Daisy Chaining, USB and USB Type-C cannot daisy chain at all and they must be plugged into a Star Topology, e.g. directly into the computer or into the Thunderbolt Dock/Hub itself.
Thunderbolt Networking enables two hosts and several devices that have a Thunderbolt controller to be connected together in a linear (Daisy chain) series from a single port.
Thunderbolt Networking for Linux is compatible with Thunderbolt Networking on systems running macOS or Windows and also supports Thunderbolt generation 2 and 3 controllers.
The Thunderbolt Networking also supports backward compatibility i.e you can connect between two computers having two different Thunderbolt Controllers, specifically, one side having Generation 2 or Generation 3 Controllers or vice-versa.
In addition of tunneling PCIe, Display Port, and USB traffic, Thunderbolt allows connecting two hosts (domains) over a Thunderbolt cable. It is possible to tunnel arbitrary data packets over such connection using high-speed DMA rings available in the Thunderbolt host controller.
In order to discover Thunderbolt services the other host supports, there is a software protocol running on top of the automatically configured control channel (ring 0). This protocol is called XDomain discovery protocol and it uses XDomain properties to describe the host (domain) and the services it supports. Once both sides have agreed on what services are supported, they can enable high-speed DMA rings to transfer data over the cable.
The XDomain protocol and networking support is available in Windows, macOS, and Linux and therefore, it is possible to connect Windows to macOS and Linux and vice-versa. When connecting Linux to a macOS or a Windows based system, everything is done automatically as those systems have the networking service enabled by default. However, for a Linux-to-Linux connection over Thunderbolt, one host needs to load the networking driver first so that the other side can locate the networking service and load the corresponding driver.
The XDomain Protocol is used by FireWire and Thunderbolt.
Thunderbolt Boot Support
Thunderbolt Security
VT-d based DMA protection helps prevent security threats by remapping requests from external devices and checking for proper permissions.
With the release of Thunderbolt devices and connections, many users are gearing up for improved connectivity and universal compatibility. One of the notices that came with the release of Thunderbolt™ 4 and could be flying under the radar is that it now comes with VT-d DMA protection standard. While this is also a major upgrade to the technology, not that many people might understand what VT-d DMA protection is and why it matters.
Intel® Virtualization Technology for Directed I/O (VT-d), specialized hardware capabilities built into Intel processors is the foundation for DMA protection on Thunderbolt ports that helps prevent physical DMA attacks. These solutions block peripheral devices from unauthorized access to system memory. Leading Operating Systems such as Windows, macOS, and Linux have already implemented DMA protection using Intel VT-d Technology. Intel’s Thunderbolt 4 certification requires VT-d based DMA protection. It is strongly recommended on computers utilizing Thunderbolt (either AIC or Onboard) and has been enabled on systems, where supported.
With USB-C connector-based computer ports that provide PCI Express (PCIe) Protocol, users can connect PCIe devices to the computer just as if they were installed internally. Such devices include Portable and Desktop Storage, External Graphics (eGPU), Audio Interface, Memory Card Readers, Ethernet Adapters, and other PCIe-based devices. PCIe devices are unique because they are capable of Direct Memory Access (DMA), which enables fast and efficient access to the system memory without involving the processor. However, shared memory between all the different devices in the system including those that are externally connected via the USB-C port may present a security risk if not properly protected. Security for Thunderbolt computer ports is hardware-based and built on Intel’s Virtualization Technology for Directed I/O (Intel VT-d), an Intel processor technology that provides IO virtualization (often referred to as IO Memory Management Unit or IOMMU). One of VT-d technology’s features is DMA remapping (DMA-r) which is used for DMA protection by operating systems and BIOS. DMA-r helps protect the system memory by providing an isolated memory region for each device connecting to the system. This way a device will only have access to its assigned memory and cannot read or write to other memory areas outside its own.
The following Operating Systems versions have VT-d and DMA-r based protection against DMA attacks on Thunderbolt™ computer ports:
• Windows OS implementation, known as Kernel DMA Protection, exists on all Windows 10 versions starting with 1803 (RedStone 4) and is enabled by default on systems that support it. See Kernel DMA Protection for more information.
• macOS/OS X implementation, known as AppleVTD, exists on all macOS/OS X versions starting with OS X Mountain Lion (10.8.2) and is enabled by default on Macs since 2012. See Thunderbolt Device Driver Programming Guide for more information.
• On Linux VT-d based security has been supported since Kernel version 4.21.
Operating system implementation helps protect the system during run time. In order to help protect against DMA attacks before the system boots and until the transition to the operating system, Intel has implemented UEFI firmware (BIOS) support for DMA-r based security that helps block devices from unauthorized access to system memory. Although physical attacks may be hard to perform and require that an attacker possess your PC, nonetheless, Intel recommends standard security practices to reduce the risk of physical attacks. Such practices include using only trusted peripherals and preventing unauthorized physical access to computers. Hard disk drive (HDD) and Solid State Drive (SSD) encryption and a BIOS Password can provide an additional layer of protection.
Security Levels
Since Thunderbolt presents some unique security considerations, there are several different "Security Levels" for a system equipped with Thunderbolt Controller that can be configured in the system's BIOS. Depending on the manufacturer, a particular Security Level can be implemented as a default Security Level in the UEFI Firmware (BIOS) of the designated system. This Security Level is also present in the Thunderbolt Firmware, and is useful in cases where no Thunderbolt Support is present from the manufacturer's end, either in the System's UEFI Firmware (BIOS), or in terms of Hardware.
The reason the Security Levels were introduced is because Thunderbolt allows access to PCIe, which poses unique security considerations that do not apply to standard USBs, and the fact that the connected devices can be DMA masters and thus read contents of the host memory without the CPU and OS knowing about it. There are ways to prevent this by setting up an IOMMU but it is not always available for various reasons. Security Levels prevent malicious TB devices from accessing the PCIe domain, thereby protecting against:
• Device-to-host DMA attacks
• Device-to-device (P2P) DMA attacks
• PCI ID spoofing to target vulnerable device drivers
• TLP source ID spoofing
The Security Level is only present on Thunderbolt Compatible Systems, i.e. a system that either has an Onboard Thunderbolt Controller or has the option to install Add-In Card (AIC) Thunderbolt Controller (such as Gigabyte GC-Titan Ridge or ASUS THUNDERBOLTEX3/TR) and is completely absent on systems where no Thunderbolt Support is present from the manufacturer's end and these Security Levels will not tend to appear even by installing a suitable Add-In Card (AIC) Thunderbolt Controller to the system. This is because several Thunderbolt EFI Modules are always missing from the UEFI Firmware (BIOS) on non-compatible Thunderbolt systems. It's worth noting that these Security Levels will only appear in UEFI Setup Menu when the Thunderbolt Controller is turned on in BIOS.
The Thunderbolt Security Levels only apply to PCIe Protocol, while DisplayPort connects by default as it has no DMA capability exposure. Therefore, these modes only come into play when connecting Thunderbolt Devices. They do not apply when connecting a USB Device to a Thunderbolt Port. Do note that these Security Levels are usually manufacturer dependent.
Starting with the Intel Falcon Ridge Thunderbolt Controller, there are 4 Security Levels available, and with the release of Titan Ridge, adding one more Security Level (USBOnly). The security levels are as follows:
SL0 (No Security)
When the Thunderbolt Controller is set to SL0 Mode, you can connect any Thunderbolt 3 device and it will immediately start working. In this mode, all connected Thunderbolt Devices are automatically connected and no user approval is needed. The danger to this mode is that since Thunderbolt supports PCIe, and PCIe allows direct access to system memory, a malicious Thunderbolt device could access potentially sensitive data in your system’s memory, and in SL0 mode, the device would simply need to be plugged in to do so. The typical threat model here would involve an attacker doing this while you had left your system unattended somewhere. This may not be a practical risk for everyone, but it's why the higher security levels exist.
SL1 (User Authorization)
When a Thunderbolt Device is connected, the user is asked for permission to allow to connect a particular Thunderbolt Device and the user must respond to a popup dialog box to explicitly allow the connection. This is the default mode and requires administrator level access to add new PCIe enabled devices. This mitigates the SL0 risk described above.
The Thunderbolt™ software (Intel Thunderbolt Control Center) on the PC maintains a list of the Unique IDs for every Thunderbolt™ peripheral that has received user permission to “always connect.” (Access Control List). If the Unique ID of the Thunderbolt™ peripheral is not on the ACL, the PCIe connection is not allowed until the user responds to a connection prompt, typically with the following options: (1) Connect one time, (2) Always connect, (3) Do not connect. Depending on the user preference, the user can choose between these options to allow once or to always allow or deny the particular Thunderbolt Device. Do note that the connection permissions are managed per PC, and not per user login.
SL2 (Secure Connection)
Similar to SL1 mode, but with the addition of cryptographic authentication. In this mode, a hardware based security challenge/response mechanism is involved.
The first time a Thunderbolt™ peripheral’s Unique ID is granted “always connect” PCIe access, a cryptographic key is written to the peripheral controller’s non-volatile memory and added to the host PC’s ACL list in order to perform a more robust "identity verification" of that particular device on subsequent connections, using a challenge/response mechanism, to ensure only specific, approved devices are allowed to connect to the system. Each time a peripheral’s Unique ID is found on the ACL, the PC’s controller sends a security challenge. The response from the peripheral is then verified before the PCIe connection is allowed. If the response is not valid, the user receives a connection permission prompt to allow or deny the connection.
This prevents an attacker from taking the Unique ID of a peripheral that had been granted "always allow" access and cloning it onto a malicious device, which under SL1 mode would allow that malicious device to gain "always allow" access. However, not all Thunderbolt 3 peripherals support SL2. Beyond the new hardware cryptographic authentication, the user experience is the same as SL1.
SL3 (DisplayPort and USB only)
When the Thunderbolt Controller is set to SL3 mode, the Thunderbolt Port will provide USB, Power Delivery, and DisplayPort functionality. In this mode, only DisplayPort traffic is allowed over Thunderbolt Port, but not the PCIe, and will not tunnel or transmit PCIe data. This will allow you to automatically connect to DisplayPort and USB devices only. No Thunderbolt Adapter or PCIe devices are allowed to connect including eGPU.
However, when a Thunderbolt device is attached, a Thunderbolt link will be established, but PCIe will not be tunneled through that link, which can result in either no functionality or limited functionality for an attached Thunderbolt device. This is because the SL3 mode blocks the PCIe function, and as a Thunderbolt device requires PCIe transmission to transmit the PCIe data between the host and the Thunderbolt device, any connected Thunderbolt Device or a Device connected through Thunderbolt peripheral will not function at all.
This is still different from a regular USB Type-C DisplayPort connection because an actual Thunderbolt link is still established, which means that if the Thunderbolt controller has two DisplayPort interfaces wired to it from the system's GPU (which is optional in the Thunderbolt spec), they would both be available, thereby offering more display bandwidth than a regular USB Type-C DisplayPort connection, where at most one full DisplayPort interface of bandwidth is available.
The "USB" portion of this security level is where it gets tricky. If you plug a variety of USB3.x device or a regular USB Type-C Dock (i.e. non-Thunderbolt Dock) into your Thunderbolt Port, it will work as normal, since this particular scenario doesn't involve an actual Thunderbolt link. However, as outlined in the "Thunderbolt Connection Modes" above, USB 3.x is not natively carried over an actual Thunderbolt 3 link. This means if the system is set to SL3 mode and when an actual Thunderbolt Dock is connected, you will get the display output, but you will not be able to use any USB 3.x ports or other dock functionality that runs through the dock's USB Controller (typically all the other ports like Ethernet, Audio, etc.). This is because the SL3 mode blocks the PCIe transmission, which prevents transmitting the data between the dock and the system, and as those functions are dependent on PCIe, they will not function at all.
The only USB functionality you could potentially get from a Thunderbolt Dock would be anything that runs as USB 2.0, since as mentioned earlier, a USB-C connector contains dedicated pins for USB 2.0, and that traffic runs completely independently of Thunderbolt. However, even USB 2.0 devices connected to the dock's USB ports and internal dock devices that run on USB 2.0 (possibly the dock's audio controller) would still typically run through the dock's own PCIe-based USB controller rather than being passed straight through to the attached system as native USB 2.0.
\\\Recommend using this mode only when there is no requirement to support Thunderbolt™ peripherals, or Thunderbolt™ peripherals that only require the DisplayPort interface to be fully functional.///
SL4 (Daisy Chaining Disabled/USB Docks Only)
This mode refers to Thunderbolt Daisy Chaining, not DisplayPort Diasy Chaining. This mode uses an Intel® proprietary approach to terminate the PCIe tunneling within the first Thunderbolt Device connected to a Thunderbolt host port. In this mode, PCIe is allowed, but only for the first Thunderbolt Device in the chain, and would not be allowed to use the PCIe function to connect any further Thunderbolt Devices down the chain.
This means if the system is set to SL4 mode and you have a Thunderbolt device that has daisy chaining capability, connecting that particular device to a Thunderbolt port will be fully functional, but if you connect any other Thunderbolt device to that particular Thunderbolt device, it will be completely blocked from connecting and will not function at all. This mode is designed to prevent a malicious Thunderbolt peripheral from gaining access to your system through a trusted device (such as a dock) when using a Daisy Chain setup.
For example, if you connect a Thunderbolt SSD into an "upstream" Thunderbolt port on your Thunderbolt Dock, and you connect that dock to your system while the system is set to SL4 mode, the Thunderbolt Dock would be allowed and will be fully functional, but the Thunderbolt SSD would be blocked and will not function. This is because the SL4 mode disables the Daisy Chaining, which prevents PCIe tunneling for the rest of the Thunderbolt Devices connected to the first Thunderbolt Peripheral in a Daisy Chain mode.
In addition, when the system is set in SL4 mode, the user will not be able to Daisy Chain Thunderbolt Devices from Thunderbolt Port B.
If the security level reads as user or secure the connected device must be authorized by the user before PCIe tunnels are created (e.g the PCIe device appears).
IOMMU
Thunderbolt Bandwidth
Although Thunderbolt 3 is capable of delivering speeds up to 40Gb/s, the actual throughput
Although the maximum throughput is 40Gb/s for Thunderbolt, the actual speed bandwidth depends on the end Thunderbolt Device. For example, if you connect an end Device that is TB2 (capable of 20Gb/s), you'll get 20Gb/s instead of 40Gb/s. This is because to utilize a proper 40Gb/s speed, the Thunderbolt Controller and the end connected Device should be of the same speed.
Following are the requirements for enabling Thunderbolt 3 HotPlug on macOS. Please ensure you meet the requirements before proceeding with this guide.
Enabling hotplug can be a quite complex process and time consuming. But if done correctly, you can have a working Thunderbolt with hotplug feature with the required speed and performance.
Following are the test devices used as an example for this guide which features Audio Interfaces, Dock, and Thunderbolt drives. From consumer series to HEDT series motherboard, it works as expected.
Thunderbolt Devices:
Motherboards:
Thunderbolt Status
Following are the Thunderbolt Status for the following Thunderbolt Hardware. The table provides the functionality and features with Hotplug for several devices and with different Thunderbolt hardware setups such as Multiple Alpine Ridge and Titan Ridge Card for a TB extensive workflow.
Notes:
Notes:
Notes:
Thunderbolt Firmware Configuration
There can be normally two firmware configurations for Thunderbolt 3. Original and Custom firmware Configuration. Both of them have been described below.
Thunderbolt Setup Configuration
There can be normally two configurations for Thunderbolt 3. Single Card and Multiple Card Configuration. Where, a single card offers up to "two" thunderbolt 3 ports and multiple cards can offer up to "twelve" thunderbolt 3 ports depending on the PCIe slots available where one slot is always reserved for the GPU. These can be further categorized into four more configurations which are outlined below.
Selecting Thunderbolt Configuration
Depending on your need for Thunderbolt, where the key factor can be the requirement of each individual Thunderbolt 3 port, select your configuration and start the preparation for Thunderbolt 3 Hotplug. If you're looking for a simple Thunderbolt with Hotplug functionality and don't want to flash a custom firmware due to the complexity of the guide or are not willing to take risk, the best choice would be to go for a single card with the original firmware. However, even if you don't want to flash your Thunderbolt with custom firmware, you may need to flash it for some devices which require Thunderbolt Bus to utilize a particular Thunderbolt device.
Flashing Custom Firmware
If you're planning to flash the custom firmware depending on your Thunderbolt needs, @mooseknuckleboi has written a very well guide explaining flashing Thunderbolt Cards for macOS. You can find more information for his thread linked below.
www.elitemacx86.com
Enabling Thunderbolt 3 Hotplug
Now, you have enough information about Thunderbolt configuration, firmware, and the limitations and the next step is to enable Thunderbolt Hotplug. To enable Hotplug, follow the steps outlined below.
Following are the steps to enable Thunderbolt 3 HotPlug.
STEP 1: Enable Thunderbolt
This guide assumes that you're already having Thunderbolt 3 enabled on your hardware, with the exception of HotPlug. As this guide requires a working Thunderbolt to grab ACPI paths, it is important that you enable your Thunderbolt first. If you don't have the Thunderbolt enabled, refer to the guide linked below.
elitemacx86.com
Single Card and Onboard Thunderbolt
STEP 2: Getting the ACPI path
Before you start preparing the SSDT, it's recommended to find the ACPI path of the Thunderbolt Card.
For Single Card and Onboard Thunderbolt:
1. Connect any Thunderbolt device to the Thunderbolt port and boot the system into macOS.
2. Download and open IOReg and type Thunderbolt in the search bar. You should see something similar to the screenshot attached below.
4. Once you have located the Thunderbolt node, you can clear the search to get the complete node info.
5. If you check, in the above screenshot, we have some Thunderbolt and USB connectors listed. You need to locate your current path which is driving the connection to the Thunderbolt. A simple way to find this out is to just find the path having Thunderbolt properties with AppleThunderboltHAL. In our case, it is
STEP 3: Obtaining Sample Thunderbolt SSDT
The next step is to obtain a sample Thunderbolt SSDT for enabling HotPlug. To obtain the sample Thunderbolt SSDT, follow the steps below.
1. Open HackinDROM website in your web browser.
2. Depending on your Thunderbolt chipset, select the appropriate Thunderbolt Controller from the drop-down list. If you're having an
3. Once you select the Thunderbolt model from the drop-down list, the download button will appear. Click on the Download button to download the sample Thunderbolt SSDT.
STEP 5: Changing the ACPI Path
Now, we have got the ACPI path of the Thunderbolt. To enable the hotplug, you must change the ACPI path to match yours.
Once you have obtained the ACPI path of the Thunderbolt, the next step is to change the ACPI path in the Thunderbolt SSDT to enable Hotplug. To change the ACPI path, follow the steps below.
1. Download MaciASL of your choice.
2. Extract the MaciASL and move it to the Applications folder
3. Open the downloaded
4. Depending on your ACPI path, change the ACPI Path with the value obtained in the STEP #1. In our case, the ACPI path would be
Before changing:
After changing:
6. Click on compile and look for errors in the Compiler Summary. If there's an error, fix it and again click on Compile.
Removing additional address
For a few systems (usually Broadwell and older and some AMD) having onboard or single Thunderbolt Card installed, you'll need to remove an additional address in the SSDT. Although, this is dependent on the CPU, the amount of PCIe Devices installed and the BIOS version, this may not be the always case and your configuration may differ. This step should be only used if you have an address like below.
1. Depending on your ACPI path, you'll need to remove the External method from the sample SSDT. In our case, the system has
Now, as our system does not have the
However, depending on the system you have and the sample SSDT you obtained, the external method may differ and you'll have to remove the external method accordingly.
2. As we have removed the
Before removing:
After removing:
3. Click on compile and look for errors in the Compiler Summary. If there's an error, fix it and again click on Compile.
Defining additional address
For Desktop Motherboards starting with 500 series and newer, you'll also need to define an additional address in the SSDT.
1. Copy the following External method
2. Paste it just two lines above from the External (DTGP) line and adjust the External method as per your ACPI Path. In our case, it would be PC00.RP09.
Before changing:
After changing:
3. Copy the following Scope
4. Put two space at the end of the first scope and paste it below the first Scope
Before changing:
After changing:
5. Click on compile and look for errors in the Compiler Summary. If there's an error, fix it and again click on Compile.
STEP 6: Changing the Slot Configuration
The slot configuration is purely cosmetic but is helpful when debugging and makes the Thunderbolt nearly perfect. For onboard Thunderbolt, the slot name should be configured as
For systems with onboard Thunderbolt, the sample SSDT should be good to go as it's already configured as "Thunderbolt". To change the slot info for Single Thunderbolt Card, follow the steps below.
1. Open the modified
2. Depending on the slot which has the Thunderbolt Card installed, change the value of
Before changing:
After changing:
4. Save the changes to the SSDT using
STEP 7: Renaming the SSDT
For Onboard Thunderbolt, rename the
STEP 8: Installing the SSDT
The next step is to install the SSDT for enabling the HotPlug. Follow the steps below to install the SSDT.
1. Mount your ESP
For Clover
If you're using Clover, copy SSDT-DTGP.aml and the related SSDT-TB3.aml to EFI/Clover/ACPI/patched directory.
For OpenCore
If you're using OpenCore, copy SSDT-DTGP.aml and the related SSDT-TB3.aml to EFI/OC/ACPI directory. You'll also need to add the ACPI entries in ACPI>Add section of your config.plist
3. Save your config.plist
STEP 5: Restarting your System
Multiple Thunderbolt Setup
The next step is to find the ACPI path of the Thunderbolt Card. Without the correct path, the Thunderbolt SSDT will never load and as a result, the HotPlug will never work.
Getting the ACPI path for multiple cards is much more complex than the onboard and single Thunderbolt card setup. Follow the steps below to get the ACPI path.
You can install all the Thunderbolt Cards and get multiple ACPI paths or can also use one card in each particular slot and then get the ACPI path.
1. To check the ACPI path, just open IOReg and type Thunderbolt in the search bar.
In our case, it's
2. However, this is the first phase of the ACPI path. To complete the second phase, you'll need to use a Thunderbolt SSDT and adapt for every slot except PXSX and note down the new ACPI path. Note that normally its PEGP. However, we recommend you to go through the second phase and confirm the ACPI path to make sure there is no fluke.
For Slot #3
STEP 4: Configuring Thunderbolt Bus ID
With a Multiple Thunderbolt setup, you'll need to configure the Thunderbolt Bus ID for each of the Thunderbolt Card installed. The Thunderbolt Bus ID configuration is necessary for multiple Thunderbolt Controllers to make sure there is no conflicts between the multiple controllers. Each unique Bus ID represents each unique Thunderbolt Controller. To configure the Thunderbolt Bus ID, follow the steps below.
1. After selecting the Thunderbolt model from the drop-down list, click on the
2. Under the
3. Once you've set the Thunderbolt Bus ID, click on the
4. Click on the Download button and the SSDT will be downloaded/saved to your system's configured download location in your browser.
5. You'll need to refresh the website and repeat the steps 1-4 for configuring the Thunderbolt Bus ID for each of the Thunderbolt Card you have installed. This step is necessary for multiple Thunderbolt Controllers to make sure each Thunderbolt Controller has a unique
STEP 3: Changing the ACPI Path
Once you have obtained configured the Thunderbolt Bus ID, the next step is to change the ACPI path.
STEP 5: Changing the ACPI path
1. Open the downloaded SSDT
For single cards and onboard Thunderbolt, the steps are very simple.
If we consider our first Thunderbolt Card, which is installed on Slot #2 as the Slot #1 is reserved for GPU, the change to the SSDT, would be the following.
2. Click on Replace checkbox in the right corner.
3. Type PCI0 in the first search box and type PC00 in the second search box.
4. Click on All and the changes would be like the screenshot attached below.
For Multiple Thunderbolt Cards:
For Multiple Thunderbolt Cards, you'll need to perform some additional steps.
If we consider our second Thunderbolt SSDT, here would be the changes.
3. Type PCI0 in the first search box and type PC01 in the second search box.
5. Type RP21 in the first search box and type BR1A in the second search box.
6. Click on All and the changes would be like the screenshot attached below.
8. Click on All and the changes would be like the screenshot attached below.
Adding additional External Definition Block
If you remember the step of "Getting ACPI Path", you may have noticed that for the second Thunderbolt Card, the path was PC01.BR1A.SL01 but here we have been using PEGP. Hence, we need to add PC01.BR1A.SL01 and also define SL01. To do that, follow the steps below.
1. Copy the following External method.
2. Paste it just above the External (DTGP) line.
Once changed, the SSDT should look like the screenshot attached below.
4. Paste it just above the "Scope (PEGP) line.
Click on Compile button and save the SSDT.
STEP 6: Slot Configuration
The slot configuration is purely cosmetic but is helpful when debugging and makes the Thunderbolt nearly perfect. For systems with multiple Thunderbolt Card installed, the Slot name should be configured as
1. Open the modified SSDT-TB3-HackinDROM.aml using MaciASL.
Before changing:
After changing:
3. Repeat the same steps for each of the SSDT applicable for each of the Thunderbolt Card.
STEP 7: Renaming SSDT
For multiple Thunderbolt Card setup, it's strongly recommended to rename the related
1. Mount your ESP
For Clover
For OpenCore
STEP 9: Restart your System
Connect any TB Device and you're good to go!
Verifying HotPlug
The next step is to verify whether the HotPlug is working or not. Follow the steps below to verify the HotPlug.
Test Results
Following are the test results for various motherboards and Thunderbolt Devices.
FAQ [Frequently Asked Questions]
Q. Is my Thunderbolt Compatible?
A. All the Thunderbolt models and Family listed above, at the starting of this guide are compatible and has been tested. If you have any other model and Family, feel free to post or create a separate thread.
Q. I don't see Thunderbolt information under System Report>Thunderbolt. I only see "No Drivers are loaded". Is that normal?
A. Yes, it's very normal. The reason you don't see the Thunderbolt information is due to the lack of Thunderbolt Bus, which typically requires flashing the card with a custom firmware that activates Thunderbolt Bus.
Q. Is it necessary to Flash Thunderbolt Card?
A. Yes, it's necessary if you want to use any special device which requires Bus Activation and networking capability and when using multiple Thunderbolt cards on one motherboard. Devices like Drobo require a bus activation.
Q. I've flashed my Thunderbolt Card with custom firmware. Do I still need to use SSDT?
A. Yes, you'll need to use the SSDT regardless of the case. The SSDT is what provides PCI Device, Hotplug and Bus ID.
Q. Can I activate TB Bus ID without the need of flashing the custom firmware on Alpine Ridge?
A. Yes, you can.
Q. Can I activate TB Bus ID without the need of flashing the custom firmware on Titan Ridge?
A. It may be possible. But as of now, no information is available yet.
Q. I cannot use the Audio Interface from Antelope, Presonus, Slate Digital, Focusrite, and Apogee Digital?
A. Yes, that's a well-known issue. For more information, refer to the setup linked below.
elitemacx86.com
Should i disable Thunderbolt?
If you don't have any Thunderbolt Device and don't have plan at the moment or simply don't have the use case, consider it disabling to save more battery. However, disabling the Thunderbolt will also stop the Type-C function.
Problem Reporting
Details:
Credits :
Intel
Apple
LWN
KGP
DSM2
CaseySJ
Elias64Fr
Osy
BerndVP
Mooseknuckleboi
Ferz
OmegaRed1723
Sample Attachment
The ACPI files are attached below which has been used as an example in this guide.
GUIDE - How to Enable ThunderBolt on macOS
How to Enable ThunderBolt 2, Thunderbolt 3 and Thunderbolt 4 on maOS [Clover/OpenCore] An EliteMacx86 Exclusive Guide - This guide covers implementation of Thunderbolt 2, Thunderbolt 3 and Thunderbolt 4 on macOS using Clover and OpenCore. Overview This guide covers the implementation of...
GUIDE - How to Enable Thunderbolt 4 Hotplug on macOS
How to Enable Thunderbolt 4 Hotplug on macOS [Clover/OpenCore] An EliteMacx86 Exclusive Guide - This guide covers implementation of Thunderbolt 4 Hotplug on macOS for built-in and Add In Card (AIC) Thunderbolt hardware. Overview Recently, Intel and Apple announced their new Thunderbolt...
- Symmetrical and flip-able, or reversible. Both sides (top and bottom) can be inserted in the port in either direction, meaning that you no longer have to make sure a cable is inserted “right-side” up.
- Delivery of up to 100W of power.
- Supports alternate modes, such as DisplayPort, Thunderbolt, etc.
- At 40 Gbps, Thunderbolt 3 is the fastest connection available. By comparison, native USB 3.1 operates at 10 Gbps.
- Thunderbolt 3 is bi-directional with four lanes of PCI Express Gen 3 and eight lanes of DisplayPort 1.2.
- Now with a Thunderbolt 3 port, you can connect to any dock, device, or display, including billions of USB devices.
USB Only Mode
Thunderbolt 3 Mode
Power Delivery
5V/3A (15W)
and 20V/5A (100W)
. This is due to the difference in the Computer Type, Power Delivery Standard, and the decisions made by the manufacturer regarding the circuit design to meet their end goal.The AIC (Add-In-Cards) can offer up to
100W
standard Power Delivery which is more than enough to charge heavy devices, including MacBooks from recent lineups which use Type-C for charging (such as MacBookPro15,1 - Mid-2018) based on Intel CPU and (MacBookAir10,1 - 2020) based on Apple M1 Silicon Chip.However, depending on the board design, the Power Delivery Spec can differ. For example, the Gigabyte GC-Alpine Ridge v1.0 and v2.0 (featuring JHL6540 - Thunderbolt 3) supports PD2.0 Standard and offers up to 5V/3A (15W) and 12V/3A (36W) Power Delivery Spec. Whereas, the Gigabyte GC-Titan Ridge v1.0 and v2.0 (featuring JHL7540 - Thunderbolt 3) supports PD3.0 Standard, with Port 1 offering up to 5V/3A (15W), 9V/3A (27W), 15V/3A (45W), 20V/5A (100W) Power Delivery Spec and Port 2 offering up to 5V/3A (15W), 9V/3A (27W) Power Delivery Spec.
(36W)
Power Delivery Spec. Despite having Thunderbolt 4, the ASRock Thunderbolt 4 AIC (featuring JHL8540) still supports PD2.0
Standard, offering up to 5V/3A (15W)
and 9V/3A (27W)
Power Delivery Spec respectively.Looking at the Data Sheet of built-in Thunderbolt Chip, certain Desktop Motherboards with an onboard Thunderbolt Chip can offer up to 9V/3A (27W) Power Delivery Spec. Whereas, this can be way more limited for Laptops (such as Dell XPS 9560/9570) offering up to 5V/3A (15W) Power Delivery Spec.
Thunderbolt Display
Technology | Announced | Bandwidth | Display Support | Connector Type |
Thunderbolt 1 | 2011 | 2x10Gbps | 1x2560x1600 @60Hz | Mini DisplayPort |
Thunderbolt 2 | 2013 | 20Gbps | 1x4K @60Hz 2x1440p @60Hz | Mini DisplayPort |
Thunderbolt 3 | 2015 | 40Gbps | 1x4K @120Hz 1x5K @60Hz 2x4K @60Hz | USB Type-C |
Thunderbolt 4 | 2020 | 40Gbps | 1x4K @120Hz 2x4K @60Hz 1x5K @60Hz 1x8K @60Hz | USB Type-C |
Target Display Mode
Daisy Chaining
Daisy Chain is yet another exciting feature that Thunderbolt offers. One Thunderbolt Device can be plugged into the end of a string of devices, one after other. This feature is referred to as Daisy Chain. Each device must be powered on for subsequent devices to operate. Thunderbolt Daisy Chaining allows you to connect multiple Thunderbolt devices to your computer. These daisy-chained devices connect in a series to communicate so a single connection can support multiple devices. Data, power, and video signals can flow from the computer and down the chain into additional connected accessories. This gives the ability to daisy-chain up to a maximum of six (6 ) Thunderbolt Devices per Thunderbolt Bus and up to a total of (twelve) 12 Thunderbolt Devices for both Bus. This means, systems having two Thunderbolt 3 chips, can give you the ability to daisy chain up to a total of 24 Thunderbolt Devices (each chip having two Thunderbolt Bus) for all four Buses.Generally, this is useful for most of the users involved in content creation (such as Music or Video Production) and helps users to maximize their productivity, reduces cable management, and gives a tidier workspace by consolidating all accessories into a single connection.
Thunderbolt Networking provides peer-to-peer connections to transfer files between computers, perform PC migrations, and/or set up small workgroups with shared storage. This is a virtual connection that emulates an Ethernet adapter that enables Ethernet networking with the benefit of Thunderbolt superfast medium capability.Thunderbolt Networking enables two hosts and several devices that have a Thunderbolt controller to be connected together in a linear (Daisy chain) series from a single port.
Security Levels
Security Level | Description |
SL0 (None) |
SL1 (User) |
SL2 (Secure) |
SL3 (DisplayPort Only) |
SL4 (Daisy Chaining Disabled/USB Docks Only) | |
SL5 (NoPCIe) |
SL0 (No Security)
IOMMU
Thunderbolt |
Motherboard |
Kexts |
Extra Hardware |
Tools |
- Element 88 from Apogeedigital
- G-Technology 3TB
- UAD Twin Apollo
- Belkin Thunderbolt 3 Mini Dock with 4K Dual HDMI
- Ash Creek NVMe
- TBT3 SSD 480
Motherboards:
- GIGABYTE Z370 AORUS GAMING 3
- GIGABYTE Z390 AORUS ELITE
- GIGABYTE Z490 VISION G
- GIGABYTE X299X DESIGNARE 10G
- GIGABYTE Z370 AORUS GAMING 7
- ASUS X299 A
- ASUS X299 PRIME DELUXE
- ASUS PRIME Z690M-PLUS D4
- MSI X299 RAIDER
- EVGA X299 Micro
Thunderbolt Status
Thunderbolt:
Function | Single Card with Original Firmware | Single Card with Custom Firmware | Multiple Cards with Original Firmware | Multiple Cards with Custom Firmware |
Booting with Thunderbolt Device Connected | YES | ![]() | ![]() | ![]() |
Thunderbolt Hotplug with Cold Boot | YES | ![]() | ![]() | ![]() |
Thunderbolt Hotplug with Warm Boot | YES | ![]() | ![]() | ![]() |
Thunderbolt Hotplug with no Device Connected at Boot | YES | ![]() | ![]() | ![]() |
Sleep with Thunderbolt Device Connected | YES | ![]() | ![]() | Inconsistent Sleep |
Wake with Thunderbolt Device Connected | YES | ![]() | ![]() | ![]() |
Shut Down with Thunderbolt Device Connected | YES | ![]() | ![]() | ![]() |
Thunderbolt Auto Reconnect after Sleep | YES | NO |
USB Type-C:
Options | Single Card with Original Firmware | Single Card with Custom Firmware | Multiple Cards with Original Firmware | Multiple Cards with Custom Firmware |
Booting with USB Device Connected | YES | ![]() | ![]() | ![]() |
USB Hotplug with Cold Boot | YES | ![]() | ![]() | ![]() |
USB Hotplug with Warm Boot | YES | ![]() | ![]() | ![]() |
Sleep with USB Device Connected | YES | ![]() | ![]() | ![]() |
Wake with USB Device Connected | YES | ![]() | ![]() | ![]() |
Shut Down with USB Device Connected | YES | ![]() | ![]() | ![]() |
USB Type-C Auto Reconnect after Sleep | YES |
Display |
Thunderbolt Display | Not Tested | Not Tested | Not Tested | Not Tested |
Type-C Display | ![]() | ![]() | ![]() | ![]() |
Type-C Display Cold Boot | ![]() | Not Tested | ![]() | Not Tested |
Type-C Display Hotplug | ![]() | ![]() | ![]() | ![]() |
Drive |
Thunderbolt Drive | ![]() | ![]() | ![]() | ![]() |
Thunderbolt Drive Hotplug | ![]() | ![]() | ![]() | ![]() |
Thunderbolt NVMe | ![]() | ![]() | ![]() | ![]() |
Thunderbolt NVMe Hotplug | ![]() | ![]() | ![]() | ![]() |
Dock |
Thunderbolt Dock | ![]() | ![]() | ![]() | ![]() |
Thunderbolt Dock Hotplug | ![]() | ![]() | ![]() | ![]() |
Thunderbolt Dock Ethernet | ![]() | ![]() | ![]() | ![]() |
Thunderbolt Dock Display Port | ![]() | ![]() | ![]() | ![]() |
Thunderbolt Dock HDMI | ![]() | ![]() | ![]() | ![]() |
Thunderbolt Dock USB | ![]() | ![]() | ![]() | ![]() |
Thunderbolt Dock Audio | ![]() | ![]() | ![]() | ![]() |
eGPU |
Thunderbolt eGPU | ![]() | ![]() | ![]() | ![]() |
Thunderbolt eGPU Hotplug | ![]() | ![]() | ![]() | ![]() |
Audio |
Thunderbolt Audio Interface | ![]() | ![]() | ![]() | ![]() |
Thunderbolt Audio Interface Hotplug | ![]() | ![]() | ![]() | ![]() |
Adapters |
Thunderbolt Ethernet Adapter | ![]() | ![]() | ![]() | ![]() |
Thunderbolt Ethernet Adapter Hotplug | ![]() | ![]() | ![]() | ![]() |
Thunderbolt 2 to Thunderbolt 3 | ![]() | ![]() | ![]() | ![]() |
Thunderbolt:
Booting with Thunderbolt Device Connected | ![]() | ![]() | ![]() | ![]() |
Thunderbolt Hotplug with Cold Boot | ![]() | ![]() | ![]() | ![]() |
Thunderbolt Hotplug with Warm Boot | ![]() | ![]() | ![]() | ![]() |
Thunderbolt Hotplug with no Device Connected at Boot | ![]() | ![]() | ![]() | ![]() |
Sleep with Thunderbolt Device Connected | ![]() | ![]() | ![]() | Inconsistent Sleep |
Wake with Thunderbolt Device Connected | ![]() | ![]() | ![]() | ![]() |
Shut Down with Thunderbolt Device Connected | ![]() | ![]() | ![]() | ![]() |
USB Type-C:
Booting with USB Device Connected | ![]() | ![]() | ![]() | ![]() |
USB Hotplug with Cold Boot | ![]() | ![]() | ![]() | ![]() |
USB Hotplug with Warm Boot | ![]() | ![]() | ![]() | ![]() |
Sleep with USB Device Connected | ![]() | ![]() | ![]() | ![]() |
Wake with USB Device Connected | ![]() | ![]() | ![]() | ![]() |
Shut Down with USB Device Connected | ![]() | ![]() | ![]() | ![]() |
USB Type-C Auto Reconnect after Sleep | YES | NO |
Display |
Drive |
Dock |
eGPU |
Audio |
Adapters |
SPECIFICATION |
Model | Controller | Family | Interface | Speed | Ports | TB Device Per Port | Display Support | Daisy Chain | Thunderbolt Header | USB Header | Additional Power |
GIGABYTE GC-Thunderbolt 2 | PCIe 2.0 x4 | 20Gb/s | 2xTB2 | 2xDP IN | 6 Devices per port | 4K | YES | YES | NO | NO | ||
GIGABYTE GC-ALPINE RIDGE Rev. 1.0 | DSL6540 B-Step | Alpine Ridge | PCIe 3.0 x4 | 40Gb/s | 2xTB3 | 1xHDMI | 2xDP IN | 6 Devices per port | 1x5K @60Hz or 2x4K @60Hz | YES | 1x | NO | |
GIGABYTE GC-ALPINE RIDGE Rev. 2.0 | DSL650 C-Step | Alpine Ridge | PCIe 3.0 x4 | 40Gb/s | 2xTB3 | 1xHDMI | 2xDP IN | 6 Devices per port | 1x5K @60Hz or 2x4K @60Hz | YES | 1x | NO | |
GIGABYTE GC-TITAN RIDGE Rev. 1.0 | DSL7540 | Titan Ridge | PCIe 3.0 x4 | 40Gb/s | 2xTB3/USB 3.1 Gen2 Type-C | 1xDP | 2xmDP IN | 6 Devices per port | 4K | YES | 1x5PIN | YES | 2x6PIN PCIE |
GIGABYTE GC-TITAN RIDGE Rev. 2.0 | DSL7540 | Titan Ridge | PCIe 3.0 x4 | 40Gb/s | 2xTB3/USB 3.1 Gen2 Type-C | 1xDP | 2xmDP IN | 6 Devices per port | 4K | YES | 1x5PIN | YES | 2x6PIN PCIE |
Thunderbolt |
Function on macOS | Alpine Ridge with Original Firmware* | Alpine Ridge with Custom Firmware* | Alpine Ridge Cards with Original Firmware** | Alpine Ridge Cards with Custom Firmware** | Single Titan Ridge with Original Firmware* | Single Titan Ridge with Custom Firmware* | Titan Ridge Cards with Original Firmware** | Titan Ridge Cards with Custom Firmware** |
Booting with Thunderbolt Device Connected | YES | YES | NO | NO | YES | |||
Thunderbolt Hotplug with Cold Boot | YES | YES | NO | NO | YES | |||
Thunderbolt Hotplug with Warm Boot | YES | YES | NO | NO | YES | |||
Thunderbolt Hotplug with no Device Connected at Boot | YES | NO | NO | NO | NO | |||
Sleep with Thunderbolt Device Connected | YES | YES | NO | NO | INCONSISTENT SLEEP | |||
Wake with Thunderbolt Device Connected | YES | YES | NO | NO | NO | |||
Shut Down with Thunderbolt Device Connected | YES | YES | NO | NO | NO | |||
Thunderbolt Auto Reconnect after Sleep | YES | NO | NO | NOT TESTED |
USB Type-C |
Booting with USB Device Connected | YES | NO | NO | YES | ||||
USB Hotplug with Cold Boot | YES | NO | NO | YES | ||||
USB Hotplug with Warm Boot | YES | NO | NO | YES | ||||
Sleep with USB Device Connected | YES | NO | NO | YES | ||||
Wake with USB Device Connected | YES | NO | NO | YES | ||||
Shut Down with USB Device Connected | YES | NO | NO | YES | ||||
USB Type-C Auto Reconnect after Sleep | YES | NO | NO | NOT TESTED |
Display |
Booting with Thunderbolt Device Connected | YES | NO | NO | NOT TESTED | ||||
Thunderbolt Display | YES | NO | NO | |||||
Type-C Display | YES | NO | NO | |||||
Type-C Display Cold Boot | YES | NO | NO | NOT TESTED | ||||
Type-C Display Hotplug | YES | NO | NO |
Dock |
Thunderbolt Dock | YES | NO | NO | YES | ||||
Thunderbolt Dock Hotplug | YES | NO | NO | YES | ||||
Thunderbolt Dock Ethernet | YES | NO | NO | YES | ||||
Thunderbolt Dock Display Port | YES | NO | NO | YES | ||||
Thunderbolt Dock HDMI | YES | NO | NO | YES | ||||
Thunderbolt Dock USB | YES | NO | NO | YES | ||||
Thunderbolt Dock Audio | YES | NO | NO | YES |
eGPU |
Thunderbolt eGPU | YES | NO | NO | YES | ||||
Thunderbolt eGPU Hotplug | YES | NO | NO |
Audio |
Thunderbolt Audio Interface | YES | NO | NO | YES | ||||
Thunderbolt Audio Interface Hotplug | YES | NO | NO | YES |
Adapters |
Thunderbolt Ethernet Adapter | YES | NO | YES | YES | NO | YES | ||
Thunderbolt Ethernet Adapter Hotplug | YES | NO | YES | YES | NO | YES | ||
Thunderbolt 2 to Thunderbolt 3 | YES | NO | YES | YES | NO | YES |
Notes:
- *Refers to Single Thunderbolt Card.
- **Refers to Multiple Thunderbolt Cards.
ASUS THUNDERBOLTEX 3 | DSLXXX | PCIe 3.0 x4 | 40Gb/s | 1xTB3/Type-C | 1xUSB 3.1 Type-A | 1xmDP IN | 6 Devices per port | 4K @60Hz | YES | YES | NO | NO | |
ASUS THUNDERBOLTEX 3-TR | JHL7540 | Titan Ridge | PCIe 3.0 x4 | 40Gb/s | 2xTB3/Type-C | 1xDP IN | 1xmDP IN | 6 Devices per port | 8K @60Hz | YES | 1x5PIN | YES | 1x6PIN PCIE |
ASUS THUNDERBOLTEX-4 | JHLXXXX | PCIe 3.0 x4 | 40Gb/s | 2xTB3/Type-C | 1xDP IN | 2xmDP IN and 1xInternal Mini DP | 5 Devices per port | 8K @60Hz | YES | 1x5PIN | YES | 1x6PIN PCIE |
Thunderbolt |
Booting with Thunderbolt Device Connected | YES | |||||||
Thunderbolt Hotplug with Cold Boot | YES | |||||||
Thunderbolt Hotplug with Warm Boot | YES | |||||||
Thunderbolt Hotplug with no Device Connected at Boot | YES | |||||||
Sleep with Thunderbolt Device Connected | YES | |||||||
Wake with Thunderbolt Device Connected | YES | |||||||
Shut Down with Thunderbolt Device Connected | YES | |||||||
USB Type-C |
Booting with USB Device Connected | YES | |||||||
USB Hotplug with Cold Boot | YES | |||||||
USB Hotplug with Warm Boot | YES | |||||||
Sleep with USB Device Connected | YES | |||||||
Wake with USB Device Connected | YES | |||||||
Shut Down with USB Device Connected | YES | |||||||
Display |
Thunderbolt Display | YES | |||||||
Type-C Display | YES | |||||||
Type-C Display Cold Boot | YES | |||||||
Dock |
Thunderbolt Dock | YES | |||||||
Thunderbolt Dock Hotplug | YES | |||||||
Thunderbolt Dock Ethernet | YES | |||||||
Thunderbolt Dock Display Port | YES | |||||||
Thunderbolt Dock HDMI | YES | |||||||
Thunderbolt Dock USB | YES | |||||||
eGPU |
Thunderbolt eGPU | YES | |||||||
Thunderbolt eGPU Hotplug | YES | |||||||
Audio |
Thunderbolt Audio Interface | YES | |||||||
Adapters |
Thunderbolt Ethernet Adapter | YES | |||||||
Thunderbolt Ethernet Adapter Hotplug | YES | |||||||
Notes:
Model | Controller | Interface | Speed | Ports | TB Device Per Port | Display Support | Daisy Chain | Thunderbolt Header | USB Header | Additional Power |
AsRock Thunderbolt 3 AIC | JHL6540 | PCIe 3.0 x4 | 40Gb/s | 2xTB3/Type-C | 1xDP IN | 1xmDP IN | 6 Devices per port | 1x5K @60Hz or 2x4K @60Hz | YES | 1x5PIN | NO | NO |
AsRock Thunderbolt 3 AIC R2.0 | JHL6540 | PCIe 3.0 x4 | 40Gb/s | 2xTB3/Type-C | 1xDP IN | 1xmDP IN and 1xInternal Mini DP | 6 Devices per port | 1x5K @60Hz or 2x4K @60Hz | YES | 1x5PIN | NO | NO |
Thunderbolt |
USB Type-C |
Display |
Dock |
eGPU |
Audio |
Adapters |
Notes:
Configuration | Description |
Original/Stock Firmware |
Custom Firmware |
Multiple Card with Original Firmware |
Multiple Card with Custom Firmware |
GUIDE - How to Flash Custom Firmware on Thunderbolt Card for macOS
How to Flash Custom Firmware on Thunderbolt Card for macOS Overview Following is a Thunderbolt firmware flashing guide exclusively for macOS. The guide is applicable for Motherboards having Built-In Thunderbolt, Laptops, and Add-In Cards. The method is tested by us on the following Add-In...
PC00.RP09.PXSX
and this is our ACPI Path. Your system can have a different one. Make sure to locate the right one.STEP 3: Obtaining Sample Thunderbolt SSDT
onboard
Thunderbolt chip, select the System Model
from the list. You'll see the list of available System Models and AIC like the screenshot attached below. The list is subject to change.
using MaciASL4. Depending on your ACPI path, change the ACPI Path with the value obtained in the STEP #1. In our case, the ACPI path would be
PC00.RP09.PXSX
.Before changing:
After changing:
PCI0.NPE7
ACPI path and the sample SSDT we obtained has the following external methods (after changing the ACPI path to match ours).
External (_SB_.PCI0.NPE7, DeviceObj) // (from opcode)
External (_SB_.PCI0.NPE7.PXSX, DeviceObj) // (from opcode)
External (DTGP, MethodObj) // 5 Arguments (from opcode)
PXSX
address, but only PCI0.NPE7
ACPI path, we need to remove the following External method above the DTGP line.
PXSX
External method, we need to remove the PXSX
Scope too so that you can only have the main path.
Scope (PXSX)
Name (_STA, Zero) // _STA: Status
Before removing:
After removing:
External (_SB_.PCXX.RPXX.HRUS, DeviceObj) // (from opcode)
Before changing:
After changing:
Scope (HRUS)
Before changing:
After changing:
Thunderbolt
due to the onboard chip directly soldered on the Motherboard and for Single Thunderbolt Card, the Slot name should be configured as Slot-X
. Where, the value of X
depends on the physical PCIe slot having the Thunderbolt Card installed. The slot counts from the very first slot present on the Motherboard (below the CPU), regardless of the slot type i.e PCIe x1, PCIe x4, PCIe x8 or PCIe x16.For systems with onboard Thunderbolt, the sample SSDT should be good to go as it's already configured as "Thunderbolt". To change the slot info for Single Thunderbolt Card, follow the steps below.
using MaciASL.2. Depending on the slot which has the Thunderbolt Card installed, change the value of
AAPL, slot-name
to Slot-X
. There are a total of 4 occurrence and you must change all 4 of them for the full effect.Before changing:
After changing:
File>Save
option.STEP 7: Renaming the SSDT
to SSDT-TB3.aml
and for systems with single Thunderbolt Card, rename the SSDT-TB3-HackinDROM.aml
to SSDT-TB3-SLOT-X.aml
.STEP 8: Installing the SSDT
1. Mount your ESP
For Clover
For OpenCore
In our case, it's
PCI0.RP21.PXSX
(for slot #2), PC01.BR1A.SL01
(for Slot #3) and PC03.BR3A.SL09
(for Slot #5).2. However, this is the first phase of the ACPI path. To complete the second phase, you'll need to use a Thunderbolt SSDT and adapt for every slot except PXSX and note down the new ACPI path. Note that normally its PEGP. However, we recommend you to go through the second phase and confirm the ACPI path to make sure there is no fluke.
For Slot #3
For Slot #5PC01.BR1A.PEGP
PC03.BR3A.PEGP
Customize
button.2. Under the
Thunderbolt Bus ID
section, change the Bus ID. You can use Bus ID starting from 0
or 1
, where the 0
or 1
belongs to the first Thunderbolt Card. For example, if you have 3 Thunderbolt Cards and you would like to use the Thunderbolt Bus from 0
, it would be 0
, 1
, and 2
respectively and if you would like to use the Thunderbolt Bus from 1
, it would be simply 1
, 2
and 3
respectively.3. Once you've set the Thunderbolt Bus ID, click on the
Compile
button.4. Click on the Download button and the SSDT will be downloaded/saved to your system's configured download location in your browser.
Thunderbolt Bus ID
and unique Thunderbolt UID
. For example, if you have 3 Thunderbolt cards, you'll need to repeat the steps 1-4 for three times so that each SSDT has a different DROM.NOTES:
1. To change that, press Command+F on your Keyboard.PCI0>PC00
1. To change that, press Command+F on your Keyboard.PCI0>PC01
RP21>BR1A
7. Type PXSX in the first search box and type PEGP in the second search box.PXSX>PEGP
External (_SB_.PC01.BR1A.SL01, DeviceObj) // (from opcode)
Scope (SL01)
NOTE:
Slot-X
, Slot-Y
and so on. Where, the value of X
and Y
depends on the physical PCIe slot having the Thunderbolt Card installed. The slot counts from the very first slot present on the Motherboard (below the CPU), regardless of the slot type i.e PCIe x1, PCIe x4, PCIe x8 or PCIe x16. This will be applicable for each of the Thunderbolt Card installed in each of the PCIe slot and the slots will be configured using the same manner i.e Card 1 (Slot-X), Card 2 (Slot-Y) and so on. To change the slot info for Multiple Thunderbolt Cards, follow the steps below.1. Open the modified SSDT-TB3-HackinDROM.aml using MaciASL.
AAPL, slot-name
to Slot-X
After changing:
as SSDT-TB3-SLOT-1
, SSDT-TB3-SLOT-2
and so on.STEP 8: Installing the SSDT
1. Mount your ESP
For Clover
SSDT-DTGP.aml
and the related SSDT-TB3-SLOT-X
directory.For OpenCore
SSDT-DTGP.aml
to EFI/OC/ACPI
directory. You'll also need to add the ACPI entries in ACPI>Add section of your config.plist3. Save your config.plist
Verifying HotPlug
Test Results
TEST HARDWARE:
Motherboard: GIGABYTE Z370 AORUS Elite
CPU: Intel Core i9 9900K
GPU: NVIDIA GTX 1080Ti
Thunderbolt: GIGABYTE GC-Titan Ridge, original firmware
macOS: macOS Big High Sierra 10.13.6
The screenshot below is with no any Thunderbolt Device connected.
The screenshot below is with the Thunderbolt Drive connected using TB2 adapter to the Motherboard.
Once the TB device is connected, the PCI looks like the following.
The Storage looks like the following.
Once the Element 88 is connected via Thunderbolt using a TB2 Adapter, the Audio looks like the following. As you can see, the transport method is TB
The screenshot below is with the Thunderbolt Audio Interface (Element 88) connected using TB2 adapter to the Motherboard.
In the System Preferences>Sound
The IOReg for the Thunderbolt Drive. As you can see, the TB Device is connected to RP21 and the Drive is connected to DSB4 node.
The IOReg for the Audio Interface (Element 88). As you can see, the TB Device is connected to RP21 and the Drive is connected to DSB4 node.
- Element88
- G-Technology
TEST HARDWARE:
Motherboard: GIGABYTE X299X Designare 10G
CPU: Intel Core i9 10980XE
GPU: AMD 5700XT
Thunderbolt: Built-in JHL7540, original firmware
macOS: macOS Catalina 10.15.7
Apollo Twin X Duo Connected.
IOReg with Apollo Twin X Connected.
Lacie Rugged 2TB Connected.
System Report>SATA/SATA Express.
DaisyChain with Port 1
UAD-2 Satellite - OCTO
Apollo Twin X - DUO Connected.
System Report>Audio
IOReg with UAD-2 Satellite - OCTO and Apollo Twin X - DUO
DaisyChain with Port 2
UAD connected to Port 1 and DSP to Port 2
UAD Connected to Port 2 and DSP to Port 1
GPU: AMD 5700XT
- Apple Ethernet Adapter
- Lacie Rugged 2TB
- UAD Apollo Twin X - Duo
- UAD-2 Satellite Thunderbolt 3 - Octo
System Report>Audio
TEST HARDWARE:
Motherboard: GIGABYTE Z370 Aorus Gaming 3
CPU: Intel Core i9 10940X
GPU: AMD RX 580
Thunderbolt: GIGABYTE GC-Titan Ridge, Original Firmware
macOS: macOS Big Sur
Type-C Devices:
GPU: AMD RX 580
Type-C Devices:
- LG 38WK95C-W
TEST HARDWARE:
GPU: AMD RX 580
Type-C Devices:
GPU: AMD RX 580
Type-C Devices:
- LG 38WK95C-W
TEST HARDWARE:
Motherboard: EVGA X299 Micro
GPU: AMD 5700XT
Thunderbolt: 3xGIGABYTE GC-Titan Ridge, custom firmware
GPU: AMD 5700XT
- TBT3 SSD 480
- Ash Creek
- eGPU
A. Yes, you can.
GUIDE - How to Enable Antelope, PreSonus, Slate Digital, Focusrite and Apogee Audio Interface on macOS
How to Enable Antelope, PreSonus, Slate Digital, Focusrite and Apogee Audio Interface on macOS An EliteMacx86 Exclusive Guide - This guide covers the implementation of Antelope, PreSonus, Slate Digital, Focusrite and Apogee Audio Interface on macOS for Thunderbolt compatible systems. Overview...
Problem Reporting
Details:
- Thunderbolt Chip and Family
- Thunderbolt Vendor/Manufacturer
- Thunderbolt Type (Onboard or AIC)
- Thunderbolt AIC PCI Slot Location
- THB_C header Availability
- TB BIOS Settings Availability
- Motherboard Model
- CPU Model
- macOS version
- Copy of IOReg (original, without Thunderbolt SSDT and with Thunderbolt SSDT injected)
- Kextcache output
- Hackintool>PCIe
- System Report>PCI
- For Clover, compress EFI/Clover, exclude the themes folder.
- For OpenCore, compress EFI/OC.
- Do not include the complete EFI folder.
- Put all files in a folder with your name, compress files as Zip and attach files using site attachments only.
- Do not use any external links.
Credits :
Intel
Apple
LWN
KGP
DSM2
CaseySJ
Elias64Fr
Osy
BerndVP
Mooseknuckleboi
Ferz
OmegaRed1723
Sample Attachment
