Bluetooth isn't working with the BCM94352HMB card
Added USBInjectAll and the output of kextstat.
USBInjectAll.kext isn't loaded. In your BIOS, make sure XHCI Handoff is Enabled. Also, reset NVRAM twice and then attach a fresh PR file.
Question: Do I need a Mini PCIe to PCIe adapter that has a USB connector on it as well?
Because the one I have right now doesn't have one, and Bluetooth isn't being detected anywhere (not on Windows, macOS or Linux).
Can you provide the current screenshot of the card installed?
It’s in my PC rn, but I have this photo that I took when I assembled the adapter (both antenna wires are plugged into the Broadcom card right now).
(This adapter doesn’t have a USB header).
Then you need an adapter with USB header. If your motherboard has an option of WiFi, simply replace it or buy a PCIe one.
My motherboard doesn't have a built in Mini PCIe slot for wireless cards, thats why I got the adapter in the first place.
Well, I guess that I'll need to wait about a month or two until the new adapter arrives.
Found this one (it even has a shield): 1611257213828.png
Found this one (it even has a shield):View attachment 2989
This should work normally along with the BT.
Finally got it and Bluetooth started working!
Thank you.
There's only one issues though: The auto unlock with Apple Watch option works for like 1-5 times, and then just stops working until I disable and then enable it again.
Do you know how to fix that?
Great.
Make sure the Auto Unlock feature is available from System Report>WiFi. Try to clear the Network Interface plists and then restart. Reset NVRAM twice and Signout of iCloud, sign in and then check.
Tried it, and it still behaves the same...
Alisson de Santana
