Is there any way to check if Airdrop will or will not work? I'd like to know is it even possible before broadcom will come.
You can try AirDrop from any Mac or Apple Device.
Hi, I am trying Ventura13.0.1 Hackintosh, there are two bluetooth in my computer, one of it is Broadcom bcm943602cs, my problem is that I can load the firm version of bluetooth, but the state is off, and address is NULL. I mapped my usb and added -btlfxallowanyaddr in the booting, the efi, pice report and IOReg are attached in the files, could you please help me check about it, I cannot thank you more!
Your implementation is neither correct for WiFi or Bluetooth.
Thanks a lot for your prompt reply! Now I just enable AirportBrcmFixup.kext for WiFi, but for bluetooth I am not sure, I noticed that BlueToolFixup.kext suits for Broadcom card and for Ventura system, so I enable BlueToolFixup.kext, but it conflicts with BrcmBluetoothInjector, which means I can not use BrcmFirmwareData and BrcmPathRAM3. So I just enable BlueToolFixup, but cases does not get better, I still get Null address and off state, where did I go wrong?
Well, it seems like you did not understand it.
Here's how it should be for macOS Monterey and newer
BlueToolFixup+BrcmFirmwareData+BrcmPatchRAM3
Thanks for your thoughtful reply! But I the problem still exist, my card is bcm943602cs, I wonder if this card does not support Ventura 13.0.1, do I need to buy another card? 1678963041910.png
I noticed that there are two bluetooth in my motherboard, will they conflict with each other?
Thanks for your thoughtful reply! But I the problem still exist, my card is bcm943602cs, I wonder if this card does not support Ventura 13.0.1, do I need to buy another card?View attachment 5646
The Card you have is definitely supported.
Yes, correct. That's why excluding the Bluetooth for the other device is recommended.
Provide Hackintool>System>Peripherals screenshot.
xxxxxxxxxx
