GUIDE Intel HD Graphics 4200/4400/4600 on macOS 10.12.x and Later on Laptops [Clover/OpenCore]
Same result mate. I am starting to get hopeless on this rig. the rest of my builds are doing well except this.
No IOReg attached. Also, are the kexts present?
Are the kexts being loaded?
Is the install Vanilla?
Hello!
I've been working on getting a Toshiba Laptop to run MacOS, but I' still struggling with getting the HD4400 to work even with all the guides I tried..
The Laptop has:
Intel Core I3 4005U
Intel HD4400
4GB Ram
I will attach my Clover EFI Folder, in which I edited the config.plist according to the tutorial.
I also put FakePCIID.kext and FakePCIID_Intel_HD_Graphics.kext in S/L/E
Hello!
The Laptop has:
Intel Core I3 4005U
Intel HD4400
4GB Ram
Your Clover folder is a mess. The directories and config.plist file is not as per the guide. Follow the guide here: https://www.elitemacx86.com/threads...ller-on-laptops-using-clover-uefi-legacy.177/
Hello I'm new here. I have an Intel HD Graphics 4400 (not 4600) and I'm trying to get it fully working. Of course I followed the guide but it didn't help (still have 4mb graphics). Everything is attached. Thanks in advance
  • CLOVER.zip
    CLOVER.zip
  • ioreg.txt
    ioreg.txt
Incomplete PR files. All files should be in a single .zip file.
The IOReg shouldn't be in .txt format. Read here: https://www.elitemacx86.com/threads/guide-how-to-make-a-copy-of-ioreg.135/
The config.plist and the CLOVER is not as per the guide. Also, some outdated kexts are being used which are invalid.
Try the following things listed below.
Use the latest version of Clover from the forum, if not already.
The config.plist isn't valid. Use the config.plist from this guide and change the fixes according to hardware: https://www.elitemacx86.com/threads/guide-creating-a-basic-config-plist-file-for-booting-macos.257/
Change the SMBIOS to iMac14,2.
In BIOS, change the DVMT pre-alloc to 64MB. Disable the PCIe Graphics and Enable Intel HD Graphics.
Use HDMI Cable for the Display.
You should be good to go.
Report with new set of PR files.
Its working! Thank you!
Similar threads
lovos33
