rBoLt168
 - Feb 8, 2019
 - Folio 9470m
 - i7
 - Intel HD4000
 - 11.0.x
 - Clover (UEFI)
 - MacBook Air
No IOReg attached. Also, are the kexts present?Same result mate. I am starting to get hopeless on this rig. the rest of my builds are doing well except this.
Your Clover folder is a mess. The directories and config.plist file is not as per the guide. Follow the guide here: https://www.elitemacx86.com/threads...ller-on-laptops-using-clover-uefi-legacy.177/Hello!
I've been working on getting a Toshiba Laptop to run MacOS, but I' still struggling with getting the HD4400 to work even with all the guides I tried..
The Laptop has:
Intel Core I3 4005U
Intel HD4400
4GB Ram
I will attach my Clover EFI Folder, in which I edited the config.plist according to the tutorial.
I also put FakePCIID.kext and FakePCIID_Intel_HD_Graphics.kext in S/L/E
Follow the guide here: https://www.elitemacx86.com/threads...ller-on-laptops-using-clover-uefi-legacy.177/Hello again, I installed Clover according to the guide and edited the config.plist according to the guide, still no fix for HD4400
I will attach my new EFI Folder because the old one was from my Boot USB
Incomplete PR files. All files should be in a single .zip file.Hello I'm new here. I have an Intel HD Graphics 4400 (not 4600) and I'm trying to get it fully working. Of course I followed the guide but it didn't help (still have 4mb graphics). Everything is attached. Thanks in advance
Its working! Thank you!Incomplete PR files. All files should be in a single .zip file.
The IOReg shouldn't be in .txt format. Read here: https://www.elitemacx86.com/threads/guide-how-to-make-a-copy-of-ioreg.135/
The config.plist and the CLOVER is not as per the guide. Also, some outdated kexts are being used which are invalid.
Try the following things listed below.
Use the latest version of Clover from the forum, if not already.
The config.plist isn't valid. Use the config.plist from this guide and change the fixes according to hardware: https://www.elitemacx86.com/threads/guide-creating-a-basic-config-plist-file-for-booting-macos.257/
Change the SMBIOS to iMac14,2.
In BIOS, change the DVMT pre-alloc to 64MB. Disable the PCIe Graphics and Enable Intel HD Graphics.
Use HDMI Cable for the Display.
You should be good to go.
Report with new set of PR files.
You should always follow the guide very precisely and it will always work.Its working! Thank you!
