Hi,
Thanks for all the explanations. However, I still have problems with Bluetooth on Monterey... Either the Bluetooth disconnects frequently, or the "bluetoothd" process starts running at full speed to use 400% of the processor and it crashes the Bluetooth.
My specs :
  • Motherboard : ASRock Z490 Phantom Gaming-ITX/TB3
  • CPU : Intel Core i9-10850K
  • GPU : AMD Radeon RX 6600
  • Network card : BCM94360NG
  • macOS version : 12.6 (21G115)
  • OpenCore version : 0.8.8
The network card (BCM94360NG) is in the M.2 key E port on the motherboard. WiFi works perfectly. Bluetooth is well mapped by USBMap.kext (HS14 = internal 255). I added -btlfxallowanyaddr flag on startup and the BlueToolFixup kext but my problems persist.
What is the problem? How to access the Bluetooth logs (and see what's wrong)? My EFI, IOreg folder and my PCIe Report are here: https://drive.google.com/file/d/1toCSCuw4Gs0972dt6EBHnb6eiFJCfhzL/view?usp=share_link
Thanks for your help
Where did I do wrong? Because I don't understand sorry...
Thanks for your help.
Read the guide and make the changes accordingly.
Can't you be more specific, please? I'm going to have to completely redo my configuration...
For me, everything was good:
✅ Creating macOS/OS X Bootable USB
✅ Preparing OpenCore EFI
✅ Gathering Files
✅ Setting up config.plist
✅ Selecting a config.plist File
✅ OS X/macOS Installation
Hi. I've been trying to make my BT work, tried every solution i've find and still don't make it. The one thing i haven't done yet is remapping usb because there is no usb\bluetooth ports and i can't understand what to to with mapping (newbie in all this hack things).
Asrock h270m-itx
intel Core i5-7500
Wireless adapter Intel 3168ngw
VT-d disabled (tried enabling too)
Above 4g decoding disabled
Clover 5151
Installed kexts:
AirPortitlwm 2.1.0
BluetoolFixup 2.6.4
IntelBluetoothFirmware 2.2.0
IntelBTpatcher 2.2.0
Lilu 1.6.3
Hackintool and Clover screenshots and SystemReport
https://drive.google.com/drive/folders/1LwoKp1VvyhmqMJH2SSsnchvcBqMlFzAU
Asrock h270m-itx
intel Core i5-7500
Clover 5151
Installed kexts:
AirPortitlwm 2.1.0
BluetoolFixup 2.6.4
Lilu 1.6.3
As the guide says, you should map the ports first.
Ok, i've made it work simply by USBInjectAll.kext, and then remapped it the proper (i guess) way. In both ways BT itself works fine, but is it possible to make AirDrop and Handoff work too?
Intel Wireless AC 3168ngw, factory card for Asrock h270m-itx
AirDrop may not work as expected on such cards. Better to replace with Broadcom.
shakk
