Intel HD Graphics 4200/4400/4600 on macOS 10.12.x and Later on Laptops
An EliteMacx86 Exclusive Guide - This guide covers fixing of Intel HD Graphics 4200/4400/4600 on Laptop. By following this guide, you'll be able to achieve full QE/CI on your Hackintosh.
macOS supports a wide range of Intel HD Graphics (also referred to as iGPU) but some of them might not work out of the box, if you have not followed the config.plist creation guide.
Before you start with this guide, please know something about the performance. Graphics enhance the performance and helps to work smoothly. In macOS, full acceleration requires that both Quartz Extreme and Core Image (QE/CI) should work together.
Quartz Extreme and Core Image (QE/CI) should work together to enable full acceleration on macOS’s GUI. It utilizes the complete Graphics capabilities. In case if you haven’t enabled QE/CI on your graphic card, you won’t be able to use your macOS smoothly and there would be lots of lags and artifacts, graphic related issues and poor refresh rate. Also the dock would not be transparent. Therefore it is very important to ensure that your graphic is working with full QE/CI.
BIOS Setting
The BIOS settings has been provided in a separate thread. For more information on BIOS settings, refer to the thread linked below.
www.elitemacx86.com
Config.plist
The config.plist file must be as per the guide.
For Clover:
www.elitemacx86.com
For OpenCore:
www.elitemacx86.com
Restart your System
Now you should be able to get your Intel HD Graphics 1536 MB will full QE/CI. And your Dock would be also transparent.
Problem Reporting
Details:
Credits :
Graphics | Intel HD Graphics 4200/4400/4600 |
Kexts | Original Graphics kexts in S/L/E |
macOS Version | macOS Mojave 10.12.x or later |
BIOS Setting
BIOS/UEFI Settings for macOS (Intel/AMD)
BIOS/UEFI Settings for macOS (Intel/AMD) Most motherboards will work with only a few changes from Optimized Defaults. However, for some systems, you must change the settings for booting macOS and optimal performance. Before you start making changes to your BIOS, ensure you're running the latest...
Config.plist
For Clover:
GUIDE - How to Boot macOS Installer on Laptops using Clover (UEFI/Legacy)
Booting macOS installer on laptops can be a challenge for the new users. This guide covers a complete step to boot the macOS installer on your Laptop using Clover bootloader. Those who are not using Clover, can update their configuration for clover and continue to use it. Clover is one of the...
For OpenCore:
GUIDE - How to Create OpenCore config.plist file for booting macOS on Intel Laptops
How to Create OpenCore config.plist file for booting macOS on Intel Laptops An EliteMacx86 Exclusive Guide - This guide covers creation of config.plist for booting macOS on Intel Laptops for OpenCore as a bootloader. Overview The config.plist is a system configuration file for the Hackintosh...
Restart your System
Problem Reporting
Details:
- macOS version
- Copy of IOReg
- Kextcache output
- DPCIManager/Status
- About This Mac
- System Information/Graphics/Displays
- For Clover, compress EFI/Clover, exclude the themes folder.
- For OpenCore, compress EFI/OC.
- Do not include complete EFI folder.
- Put all files in a folder with your name, compress files as Zip and attach files using site attachments only.
- Do not use any external links.
Credits :
