dpi to hdmi
In that case, it is a normal behavior for some adapters and systems.
HDMI should be fine.
Well, HDMI only is booting properly. After boot i connect second DVI monitor and it works perfectly too. But how can I boot with two monitors at the same time? I think I should to add something in my plist, but i don't know what.
They work OOTB. Use DVI to HDMI and it should work normally.
NVIDIA with eDP connector with the patch possible or not? The patcher finds the GPU and patches it but when rebooting it doesn't boot again
No PR files attached.
can anything be done?
jonsv2
