Dell 7580 Ventura tuning
From Dell specs: described as USB 3.1 Gen 1 (Type-C) port/DisplayPort
Interestingly, spiking CPU use when using external display but not when using laptop screen only.
Attached video.
Attached video.
Assuming you're using Type-C to DP, add -igfxtypec to your boot args and provide the new PR files. Before you generate the PR files, reset NVRAM first.
Thanks, I've got audio working over DP and HDMI and verified iGPU power management as per your guide.
Latest PR files.
Currently, the process for reliably getting 4k@60Hz DP/50Hz HDMI is as described in this post:
  1. get the laptop to boot up without external monitor connected
  2. Login to the desktop
  3. Put the laptop into hibernation and close lid
  4. Plug the Display Port cable of the external monitor into the laptop
  5. Wake up the laptop
Great!
Whoa, that's a long process. But glad that there is a workaround.
Reactions: dman
Hi Dell 3080, ventura i5 10500T processor, I can't find 4k, can someone help me?
scoobypetey
