Fixing error after Mojave post installation
I got the the section of the Framebuffer using IO but I found more than one which one, Appleintelframebuffer@2 correct me if I am wrong?
second how to activate the Framebuffer.
You need to plug and check or unlock all the framebuffers if there's crashing issue.
Just remove # for the each framebuffer patch.
HI there , I followed the reset of patching the SSDT , and I patched my SSDT files using the patch rename GFX0 to IGPU & remove_PSS placeholders, but when I use the check box of drop OEM it failed to load the OS. when I unmark it loads successfully but the brightness slider disappeared and the hot keys of brightness stop work. I don't know why. all required PR attached. moreover the issue of the HDMI when I opened the IOreg. I didn't find any # to be removed as mentioned in your last reply.
The reason that it doesn't loads is cause the DSDT is not under the sorted list order. The DSDT must be also loaded under sorted order list. Moreover, you must use the full name with the file extensions as per the guide. DSDT.aml, SSDTXXX.aml and so on.
For HDMI, check Devices>Properties section.
I followed the mentioned steps and still the OS can't be loaded when using the check box of. the DROP OEM , snapshot attached.
and regarding the HDMI, I went to Devices>Properties section.
first I marked the checkbox of use Intel HDMI and it failed
second I tried to mark also HDMI injection it failed too
please be informed that the problem solved , as now the OS is fully patched and loaded with the option of drop OEM, but now one thing is left that the HDMI still not working. can you support as per my last comment there was no respond from your side.
Uncheck both the HDMI options. You were not supposed to do that.
Also, attach your native ACPI Files.
The HDMI patches are deactivated followed by the #. Remove it and then check your HDMI.
How can I do that , I tried to search for the # and I didn't find anything , moreover form devices>properties I don't know what to do
could you explain
hi there , please be informed that I opened my plist with Xcode, and in the section of properties > graphics , I removed all the # sign from all the framebuffer and then I tried to connect the HDMI put the problem still exist. and the OS power off and restart. please find the PR
xmax114
