How to Configure Post Installation on macOS [Clover/OpenCore]
Before you configure the Post Installation for your System, make sure you have installed macOS. If you have not installed macOS yet, follow one of the installation guides linked below.
Clover Installation Guide
OpenCore Installation Guide
Before you start fixing the different areas of the post installation, you should make a note of working and non-working things. Depending on the System and with how much precision the guide was followed, you will have:
Desktops
  • Graphics Acceleration with QE/CI (If using a compatible GPU)
  • Audio (Onboard and HDMI/DP)
  • Ethernet
  • WiFi/BT (If using compatible WiFi/BT hardware). See WiFi/BT Hardware Compatibility for more information
  • AirDrop and Handoff function (If using compatible WiFi/BT hardware). See WiFi/BT Hardware Compatibility for more information
  • Encoding (H.264/H.265 (If using compatible GPU))
  • Power Management (Ivy Bridge and older requires fixing)
  • Thunderbolt HotPlug not working
Laptops
  • External Display using HDMI/DP/Type-C (Requires Framebuffer Patching)
  • PS/2 Keyboard and Trackpad (I2C requires fixing)
  • Brightness using Slider in System Preferences>Displays
  • Audio (HDMI/DP Audio requires Framebuffer Patching)
  • Ethernet
  • Brightness Control not working
  • Battery Status not working
For each issues you might have with your system, there may be a combination of DSDT/SSDT patches required or kexts or ACPI renames. Hackintool can be used to determine the various hardware devices installed you need drivers/fixes for.
Universal
The universal section contains the general post installation in order to have a stable system. This is required for Desktop as well as Laptop users, wherever applicable. Both the bootloaders are supported by this guide.
Booting from System Drive without Bootable USB
Graphics and Displays
Intel
Ventura Specific [For Skylake Users only]
NVIDIA
AMD
Apple VTD
Network
Ethernet
WiFi
Bluetooth
Audio
USB Ports
Card Reader
Power Management
Sleep/Wake
iServices
App Store
DRM
Laptop Specifics
Disable Discrete Graphics in Dual GPU Laptops
Battery Meter
Trackpad
Backlight
Keyboard Backlight
Brightness Hotkeys
DSDT and SSDT Patching
Security
Password in OpenCore Menu
FileVault
Encoding
Thunderbolt
Temperature and Monitoring
Cosmetics
PCIe Device Implementation
OpenCore GUI
OpenCore Background
Boot Chime
Multiboot
Trending Threads
Vorawit1
