Help me with EFI to install Ventura 13 in HP 15-ay012dx - Core i5 6200U / 2.3 GHz, Graphics Intel HD Graphics 520
Ventura22
HP Notebook 15-ay012dx
Intel Core i5-6200u
  1. Other
Can someone help me...
I want to install macOS Ventura in a HP Notebook 15-ay012dx - Core i5 6200U / 2.3 GHz, Intel HD Graphics 520 if possible. An EFI folder working is all I require. Already have a Ventura bootable usb but could not boot from usb it get stuck when tried to boot.
use MacBookPro14,1
use ig-platform for Kabylake may need device-id for kabylake
generate new serial number for MacBookPro14,1
use latest lilu and whatevergreen.kext (important!)
use MacBookPro14,1
I'll try to make those changes to see if it works.
I downloaded the EFI folder for the SkyLake chipset
I don't know much about making changes to all of that
but do you think you can make the changes for me to the EFI. If possible, I would really appreciate it.
Already make those changes. now boots but stops!
Officially not supported. Graphics spoofing is required.
And is your responsibility to read the guides and create a configuration from scratch to stay away from the odd issues during booting and installation.
No PR Files attached.
Your configuration is not correct and you should start from scratch
Similar threads
lingersucas
