Fixing error after Mojave post installation
Please find the attached :
Kext cachout
DPCI manager screen shot
copy from IOreg
Clover boot log
and the clover folder included the config.plist and the kexts folder.
deleted all Nvidia and AMD properties. just added the required for the intel graphic and the Audio.
now the system unable to detect the audio device.
Kext cachout
copy from IOreg
Clover boot log
You don't need to inject any Graphics properties or even for hda-gfx as it's automatically done by Lilu and WEG. The rest is handled from the Devices>Properties section. Delete all those had-gfx and graphics related injections.
The Clover/Kexts directory is not as per the installation guide. Only Other folder should be there. AHCIportinjector is likely not needed.
For a working Audio, you need to inject the proper layout ID via DSDT.
Your Audio Codec is Conexant CX8200 which can be patched using my guide. You should always choose one method. You're using AppleALC and also using the patch which has to be used with AppleHDA using my guide. AppleALC and Lilu is installed in S/L/E and also in Clover/Kexts/other. Choose one path. Remove AppleALC and Lilu from S/L/E. Remove the Audio patch from KextsToPatch section. Reboot and check the Audio.
And still, the DSDT and SSDTs has not been patched.
Reply with new sets of PR files.
I followed your reply, and I got the appleHDA.kext based on the audio codec CX8200 and removed all extra files. but still the audio device output not working. please find the attached PR.
Still, the DSDT is not patched. I mentioned to patch couple of times. Without a patched DSDT, a Laptop is hardware is not good. Patch your DSDT using the guide. Read here: https://www.elitemacx86.com/threads/guide-how-to-patch-laptop-dsdt-and-ssdts.178/
In your config.plist file, the layout ID and controller patch is disabled. Check Devices>Properties
okay I will follow the guide of how to patch DSDT, but I checked the config.plist in the device properties and I found that the layout ID =3 and the checkbox of the reset HDA is marked
I followed your last guide , and I extract DSDT using Clover bootloader F4 then I followed all the steps until the step of refs.txt and I got an error I attached it so I use this one "iasl -da -dl -fe refs.txt DSDT.aml SSDT*.aml" then I worked on the Dsl concerning the DSDT and I followed all the patched. so please check it.
regarding the extraction I used this one " iasl -dl DSDT.aml SSDT*.aml" with refs
Provide the native files from ACPI/origin
Here are the files
alvarg82
