Kpbicka
 - Aug 20, 2022
 - Lenovo IdeaCentre 510
 - Intel® Core™ i3-6100T 3.2GHz SkyLake
 - Intel HD530
 - 14.x
On your advice, I removed unnecessary lines and defined 2 connectors:
0 - a monitor is connected to it
1 - must be HDMI
System boots normally but HDMI does not work
When I changed framebuffer-con0-type from value 0200000 (LVDS) to 00080000 (HDMI) - see screenshot - then nothing happens - after reboot the image is still on the screen, although I thought it should disappear, I conclude that the patch does not work. Why?
Connectors for 0x591B0000 (mobile, 3 connectors, 39 MB) :
ID: 591B0000, STOLEN: 38 MB, FBMEM: 21 MB, VRAM: 1536 MB, Flags: 0x0000130B
TOTAL STOLEN: 39 MB, TOTAL CURSOR: 1 MB (1572864 bytes), MAX STOLEN: 136 MB, MAX OVERALL: 137 MB (144191488 bytes)
Model name: Intel HD Graphics KBL CRB
Camellia: CamelliaDisabled (0), Freq: 1388 Hz, FreqMax: 1388 Hz
Mobile: 1, PipeCount: 3, PortCount: 3, FBMemoryCount: 3
[0] busId: 0x00, pipe: 8, type: 0x00000002, flags: 0x00000098 - ConnectorLVDS
[2] busId: 0x04, pipe: 10, type: 0x00000800, flags: 0x00000187 - ConnectorHDMI
[3] busId: 0x06, pipe: 10, type: 0x00000400, flags: 0x00000187 - ConnectorDP
00000800 02000000 98000000
02040A00 00080000 87010000
03060A00 00040000 87010000
