Installing Big Sur on Dell G3 15 Gaming (3500) Black (i5)
-Update the profile with the current hardware.- can you please explain it to me more?
Everything is adjusted according to the instructions, but again the installation is unsuccessful. I'm adding a photo when the installation has stopped.
Unsucessful installation and installer not loading are two different things. Here, in your case, the installer fails to load. What macOS version are you trying to boot?
Sorry, not loading, Big Sur According to your recommendation
Okay, attach your current EFI to check further? What's the last error? Where is the new boot video?
I don't have a new boot video yet
Are you sure you're having Realtek Ethernet?
- Enable CustomSBIOSGuid in your config.plist>Kernel>Quirks
- Set Update SMBIOS Mode to Custom in PlatformInfo>SMBIOS
The notebook has the following:
Network Adapter Realtek PCIe GbE Family Controller
Network Adapter Intel (R) Wireless-AC 9462
By the question, do you think I have Realtek set up in config.plist?
I'll make adjustments tomorrow, try the installation and give info
alexito
