- Feb 25, 2021
- X299-CREATOR-1.50M
- i9-10980XE
- AMD Pro WX 7100
- MacBook Air
So,
I'm using the internal TB3 of the board to run an Sonnet Echo Express 3 with Avid HDX Card
And a CalDigit TS3-Plus.
Connection is:
- TB3 Port to Sonnet EX3 - To TS3+
I'm using the Displayport of the TS3+ to run a display.
Using 1 TB3 port for EX3 and one for TS3+ doesn't work, always one of the two TB3 devices won't connect to it's drivers.
The internsal TB3 isn't flashed with a custom firmware, because it just works fine with my devices.
So I have a Gigabyte Titan Ridge 2.0 with NVM 50 flashed.
I put it in the system with the correct SSDT for it an it's perfect recognized in MacOS.
But cold booting the system with the Sonnet EX3 connected to the Titan Ridge and the TS3+ to Internal TB3:
TS3+ working fine, EX3 doesn't light up.
So, I feel like I have to do a warm reboot everytime, is there a way to force start the Titan Ridge Card on Cold boot ?
Connection is:
