X299 i9 HEDT Sonoma Thunderbolt 3 AIC custom firmware issues
Raju79
Asrock X299M Extreme4 P1.50
Intel I9 7980 XE
XFX Radeon RX 580 Black Edition
Hey all,
I`m Martin from Germany, thank you for letting me join the forum. I'm having a hard time, trying to built an OpenCore based X299 Hackintosh with the followed hardware:
Asrock X299M Extreme 4 P 1.50
Intel I9 7980 XE
64GB Corsair Vengeance LED weiß DDR4-3200 DIMM CL16 Quad Kit
Samsung SSD 970 Evo Plus 250 GB NVMe M2
I've made the Installer by exactly following the OpenCore Install Guide, but when trying to boot, it gets sucked at: "AppleUSBHostPort-createDevice-failed to create device" I have tried it with and without mapping the USB ports , with no success. Could anyone help me to boot into the installer?
Hey all,
Intel I9 7980 XE
Hi @EliteMacx86, thanks for answering and sorry for my delay. In the meantime I´ve managed to install Sonoma on my maschine. I´ve missed to set CPU C States Support to "manual" and XHCI Hand-off to "enabled". At the moment I'm having a hard time to make my Thunderbolt AIC 3 Alpine Ridge card working properly. I flashed the cards chip with the "GC-ALPINE-RIDGE-NVM21-V3-NATA.bin" Firmware and used the provided SSDT, where I also chanced the Thunderbolt PCI path. I´ve used PC00.RP01 but I´m not quite sure, if it is the correct path or even if "ASM2142/ASM2142 UCB 31Host Controller" is the correct device? The card is sitting in the PCI Slot 3, which is the suggested port by Asrock. I have attached some pictures and an IOReg dump so it is easier to review what I´ve done. I don´t have a thunderbolt device to test yet, but I think it could be working right now without the thunderbolt device showing up correctly in OSX Sys Prefs, but the latter one is exactly what I try to achieve.
  • Sys.Rep.TB:USB4.png
  • SSDT-TBOLT3-KGP.aml
    SSDT-TBOLT3-KGP.aml
  • IOReg.zip
    IOReg.zip
That's not the Thunderbolt Device but the onboard USB Controller. Your implementation for Thunderbolt is not correct.
Ok, but where do I go wrong, is it the firmware version? Originally it´s that one used for a gigabyte alpine ridge thunderbolt 3 card. I´ve used it without further modification. Next thing is, that I don´t know if I have all bios settings needed.
For now I´m using:
(F9) Default optimized settings
OC Tweaker -> CPU Configuration -> Intel Speed Shift Technology -> Native Mode
OC Tweaker -> DRAM Tweaker -> Load XMP Setting
OC Tweaker -> DRAM Tweaker -> DRAM Frequency auf DDR4-3200 einstellen
Advanced -> CPU Configuration -> CPU C States Support -> Manual
CFG Lock -> Disabled
Advanced -> USB Configuration XHCI Hand-off -> Enabled
Boot -> CSM "disabled"
Thunderbolt:
The board only has two Thunderbolt settings, enable/ disable and security level
There might be more "hidden" thunderbolt settings, therefore I´ve already send a mail to ASRock technical support and now waiting for the answer.
But how is this card to be implemented @EliteMacx86 ?
For now I´m using:
Thunderbolt:
Disable all the TB related patches. Enable TB+Disable Security Level.
Boot and attach the PR files.
Also, if you don't have any TB device to use, what's the point in enabling TB?
orggnteng
