Catalina circle slash error after Windows update.
I have followed the steps, restarted and it boot then hang halfway as shown in the attached image.
Windows has now gone back to the blue screen: Your PC ran into a problem and needs to restart ...
What are the current BIOS settings?
No idea without verbose.
That's normal as the Windows was installed with different settings in BIOS and now as you have changed them, it will give BSOD. That's how Windows work.
MAIN
BIOS Version: 317
GOP Version: 9.0.1074
EC Version: F0KL2000.005
CPU: Intel(r) Core(TM) i7-7700HQ CPU @ 2.80GHz
CPU Fan: 3237
CPU: 59Degrees C 938mV
Total Memory: 16384MB
Intel(R) HD Graphics 630
LCD 3840*2160
USB Port: N/A
USB Port: N/A
Storage:
Serial ATA Port 0
Device Type: Hard Disk (256GB)
Model Name: Micron_1100_MTFDDAV256TBN
Battery: 100%
Access Leve: Administrator
Boot Priority:
UEFI OS ( Micron_1100_MTFDDAV256TBN)
Windows Boot Manager
(Micron_1100_MTFDDAV256TBN)
ADVANCED
Internal Pointing Device : Enabled
Wake On Lid Open : Enabled
Intel Virtualization Technology : Enabled
Intel AES-NI : Enabled
VT-d : Disabled
ASUS EZ Flash 3 Utility v03.00
Storage Device(s)
fs0:\ [196 MB]
01/16/2020 19:57 <DIR> EFI
07/10/2019 16:07 <DIR> .Trashes
07/20/2019 13:58 <DIR> .Spotlight-V100
01/16/2020 21:43 <DIR> .fseventsd
12/29/2019 00:24 <DIR> System Volume Information
SMART Settings:
SMART Self Test : ON
Network Stack : Disabled
USB Configuration
Legacy USB Support : Disabled
USB Mass Storage Driver Support : Disabled
Graphics Configuration
DVMT Pre-Allocated : 64M
SATA Mode Selection : AHCI
BOOT
Fast Boot : Disabled
CSM Support : disabled
Boot Options Priorities
Boot Option #1 UEFI OS (Micron_1100_MTFDDAV256TBN
Boot Option #2 Windows Boot Manager (Micron_1100_MTFDDAV256TBN)
SECURITY
Administrator Password Status : Not Installed
User Password Status : Not Installed
HDD Password Status : Not Installed
I/O Interface Security
Wireless Network Interface : UnLock
LAN Network Interface : UnLock
HD Audio Interface : UnLock
USB Interface Security
External Ports : UnLock
BlueTooth : UnLock
CMOS Camera : UnLock
Card Reader : UnLock
Secure Boot
Platform Mode : Setup
Secure boot : Not Active
Secure Boot Control : Disabled
Property
Asset Tag: Blank [OK or Cancel]
Colum 1 : [OK or Cancel]
Colum 2 : [OK or Cancel]
MAIN
BIOS Version: 317
CPU Fan: 3237
LCD 3840*2160
USB Port: N/A
USB Port: N/A
Storage:
Serial ATA Port 0
Battery: 100%
Boot Priority:
ADVANCED
VT-d : Disabled
Storage Device(s)
fs0:\ [196 MB]
SMART Settings:
USB Configuration
BOOT
SECURITY
BlueTooth : UnLock
Secure Boot
Property
BIOS settings seems fine now. As the BIOS is updated, you need to disable the inject ACPI and boot into macOS. Once you're booted in, re-extract ACPI and patch them.
How do I disable the injection ACPI?
Rather, how do I go about disabling the inject ACPI and boot into macOS to re-extract ACPI and patch them.
I select the second icon?
There after, what do I do? I remember you asked me to have a wired mouse before, do I need for the process?
You need to check whether the ACPI is in sorted order or just in patched directory. If it's in sorted order, you'll need to remove all the sorting and also remove the ACPI files from patched directory.
To re-extract and patch ACPI, read below
Second is the Recovery. You need to boot via third one, Macintosh HD. Like i mentioned before, the system is not booting, so i don't understand what's the purpose. You'll need either another system or a bootable USB. If you don't have any system, lend it from someone.
As far as i remember, i haven't mentioned to do so ever before.
WYLDE983
