Catalina circle slash error after Windows update.
riQ
ASUS X580VD
Intel Core i7-7700HQ
NVIDIA GEFORCE GTX 1050
10.14.x
  1. Other
I have the ASUS VivoBook Pro Which you recommended me to purchase based on it's specs.
ASUS
VivoBook Pro
intel CORE i7 7th Gen [ 7700H CPU " 2.8GHz (8 CPUs), -2.8GHz
BIOS: X580VD.317
Running UEFI Clover - dual booth Windows & Mac OS
I have just realised I had not used Windows for sometime, on Wednesday I selected windows and the desktop changed to black like settings had changed.
Used it without any issues and yesterday when I selected Windows it directed me towards an update which needed a restart.
I restarted and while the indication was an ongoing update then it went to the blue screen.
Upon restarting to check mac, it loaded with the apple icon then showed the circle slash error. This has been the same since yesterday.
The Windows error : c:/windows/system32/logfilesssrt/srttrail.txt
Today, I powered up to windows and Windows Started normally, seems to be working, the black screen reverted back to my previous desktop settings.
Mac OS on the other hand does not load, I keep getting the Circle Slash error.
Kindly assist.
ASUS
VivoBook Pro
BIOS: X580VD.317
Kindly assist.
Fix your profile first.
Is there anything in particular you need me to update?
I have updated your profile.
Is your BIOS settings correct? Provide your BIOS settings.
MAIN
BIOS Version: 317
GOP Version: 9.0.1074
EC Version: F0KL2000.005
CPU: Intel(r) Core(TM) i7-7700HQ CPU @ 2.80GHz
CPU Fan: 3237
CPU: 59Degrees C 938mV
Total Memory: 16384MB
Intel(R) HD Graphics 630
LCD 3840*2160
USB Port: N/A
USB Port: N/A
Storage:
Serial ATA Port 0
Device Type: Hard Disk (256GB)
Model Name: Micron_1100_MTFDDAV256TBN
Battery: 100%
Access Leve: Administrator
Boot Priority:
UEFI OS ( Micron_1100_MTFDDAV256TBN)
Windows Boot Manager
(Micron_1100_MTFDDAV256TBN)
ADVANCED
Internal Pointing Device : Enabled
Wake On Lid Open : Enabled
Intel Virtualization Technology : Enabled
Intel AES-NI : Enabled
VT-d : Enabled
ASUS EZ Flash 3 Utility v03.00
Storage Device(s)
fs0:\ [196 MB]
01/16/2020 19:57 <DIR> EFI
07/10/2019 16:07 <DIR> .Trashes
07/20/2019 13:58 <DIR> .Spotlight-V100
01/16/2020 21:43 <DIR> .fseventsd
12/29/2019 00:24 <DIR> System Volume Information
SMART Settings:
SMART Self Test : ON
Network Stack : Disabled
USB Configuration
Legacy USB Support : Enabled
USB Mass Storage Driver Support : Enabled
Graphics Configuration
DVMT Pre-Allocated : 64M
SATA Mode Selection : intel RST Premium
BOOT
Fast Boot : Enabled
CSM Support : disabled
Boot Options Priorities
Boot Option #1 UEFI OS (Micron_1100_MTFDDAV256TBN
Boot Option #2 Windows Boot Manager (Micron_1100_MTFDDAV256TBN)
SECURITY
Administrator Password Status : Not Installed
User Password Status : Not Installed
HDD Password Status : Not Installed
MAIN
BIOS Version: 317
CPU Fan: 3237
LCD 3840*2160
USB Port: N/A
USB Port: N/A
Storage:
Serial ATA Port 0
Battery: 100%
Boot Priority:
ADVANCED
VT-d : Enabled
Storage Device(s)
fs0:\ [196 MB]
SMART Settings:
USB Configuration
BOOT
Fast Boot : Enabled
SECURITY
So, your BIOS settings has been reset. Most probably, Windows updated the BIOS. However, even in such case, BIOS reset should not happen, unless done manually.
Setup your BIOS again and try to boot.
Which settings do I use to setup BIOS?
I have followed the steps, restarted and it boot then hang halfway as shown in the attached image.
xmax114
