News Now you can use Antelope, PreSonus, Slate Digital, Focusrite and Apogee Thunderbolt Audio Interface and NAS on Custom PC Builds and Laptops with macOS
Thanks for the reply. I have the very latest Orion Studio Synergy Core. I have an old iMac so I am using USB and the reason I want to update and build a new machine is so I can start using the Thunderbolt connection and plugins such as afx2daw.
Good to know about the NVIDIA GT 710. For the choice of hardware to build my machine is it something we can do on this thread or do you suggest any other threads on the elitemacx86 platform?
I really want to buy the most stable hardware to run any of the iOS's great to know the workaround works for any desired OS version.
That has been tested and it works like a charm!
You can start a thread in the Buying Advice forum. Very soon, it will have buying guide.
Not sure, unless i know your budget. xD
Wow, so the compatibility issues for thunderbolt and these audio devices are regardless of the hardware we buy? These are not inherently related to this thread?
I thought the hardware would or could affect the compatibility with the specific Audio Hardware, and for example that some Thunderbolt cards or adapters are better for Antelope or not.Ok!
My budget is 2000$I just wan't to make a safe choice and guidance would be appreciated.
Thanks!
Not really, the fact is interfaces like Antelope, it has never worked on modified systems with latest OS but now, it's possible.
Of course, of course a good hardware fixes lots of issues.
Thanks!
Just create a thread under Buying Advice!
Reactions: ccgrlds
Hello, first I´d like to express my gratitude for your efforts to bring solutions to the community, that's really honorable
Now, back to what brings me here,
I have a flashed GIGABYTE GC-TITAN RIDGE in my cMP 5.1 and an antelope audio orion studio synergy core.
Booting with OC makes the Orion be seen by the system straight away but when I launch the antelope launcher the unit doesn´t show up no matter what I do, reinstalling drivers/Launcher etc.
I have a bootcamp Windows10 dedicated drive and the Orion works great in there, it's recognised, everything is fine, which makes me think it's not a hardware problem.
Is there something I could try to make that thing work on the Mac side?
Regards,
Kanye W.
Thank you!
What version of the firmware and the Card?
A common issue which is already described.
Yes, Windows and Mac are two different things and of course, it's not an hardware issue. It's actually a limitation for the Hack side ;)
We're still working on the solution, but at present, the solution we have for real Macs are quite unstable and that's why we have not announced the release on this forum. And we don't have any ETA as of now.
Although, there is a quick workaround available. Our mods will reach you out as soon as possible. Refer to post #2 for additional details.
Reactions: Kanye
Sorry I´m not a very tech guy,
Are you referring to what? My MP firmware, TR, Graphics?
Titan Ridge firmware version and Titan Ridge Card Revision. V1 or V2?
OhCamargo
