Hello! I am in desperate need of some help getting my Antelope Discrete 8 Pro SC working over TB3 with my hackintosh. I have a UA Apollo that I have tested hotplug with (and it works), but have not had luck with the Antelope. I've enabled Vt-d and TB in my BIOS, but I'm not having any issues with networking.. So do I still need to do the DMAR section? Also, I'm still not seeing the Antelope interface.
Yes, but not always.
Hello This is my first post here so sorry if I'm doing something wrong but i have a question, at the end of your post you say the for AMD systems I have to use the second workaround but i can't seem to find this second workaround, I did test this method on an Intel System and it works flawlessly but on AMD I have enabled SV-T and IOMMU but i get no DMAR table to edit and I'm confused now...
On the news page you have said that AMD Systems are now supported so am i missing something here?
BTW I do not use a thunderbolt card I use a pci-e firewire 800 card with texas chipset (the same card that i used on the intel system which was fixed with your solution)
The second workaround suggested in the guide was to use macOS Sierra.
This is because the AMD does not have VT-d. Its simply not supported by the AMD processors.
The process is quite complex and this is why it was never documented.
And what problem do you have with this FireWire Card?
jonnyrec
