That''s a very common issue.
To fix it, follow the steps below.
Extract the ACPI set from your system.
Copy the SSDT1-cpu-def file and the apic.aml file to Desktop.
Rename the ssdt to dsdt.aml
Thanks mate! that did the trick with 21.5
Here is the log: https://pastebin.pl/view/9d1b30b9
The new ssdt looks much healthier than the previous one.
Somehow after restarting x86platformplugin is not loading any more with the new ssdt :/
edit: they seem to address different addresses if I'm not mistaken.
  • new_SSDT.aml.zip
    new_SSDT.aml.zip
No PR files attached.
Copy of IOReg.
Kextcache output.
EFI. Make sure to exclude resources folder.
Copy of IOReg.
Kextcache output.
kextstat
Kextstat and Kextcache are two different things.
Yeah, sorry for the goof up.
post@DESKTOP-1S52J6M ~ % sudo Kextcache -i /
Kextcache -i /
kmutil done
Is this result ok?
This method work for non -E sandybridge? (I7 2670QM)
I use sandybridge laptop on catalina10.15.7
Thanks
Thanks
Only valid for SB-E and IB-E CPU lineup.
hello, tell me, are there any bigsur patches for Ivy Bridge-E?
For Catalina fix, is the #3 just a place holder? The FIND and REPLACE strings are identical.
J.An
