That''s a very common issue.
To fix it, follow the steps below.
Extract the ACPI set from your system.
Copy the SSDT1-cpu-def file and the apic.aml file to Desktop.
Rename the ssdt to dsdt.aml
Thanks mate! that did the trick with 21.5
Here is the log: https://pastebin.pl/view/9d1b30b9
The new ssdt looks much healthier than the previous one.
Somehow after restarting x86platformplugin is not loading any more with the new ssdt :/
edit: they seem to address different addresses if I'm not mistaken.
  • new_SSDT.aml.zip
No PR files attached.
Copy of IOReg.
Kextcache output.
EFI. Make sure to exclude resources folder.
Copy of IOReg.
Kextcache output.
kextstat
  • extracted_acpi_tables.zip
  • ioreg.zip
  • oc.zip
Kextstat and Kextcache are two different things.
Yeah, sorry for the goof up.
post@DESKTOP-1S52J6M ~ % sudo Kextcache -i /
Kextcache -i /
kmutil done
Is this result ok?
This method work for non -E sandybridge? (I7 2670QM)
I use sandybridge laptop on catalina10.15.7
Thanks
Thanks
Only valid for SB-E and IB-E CPU lineup.
hello, tell me, are there any bigsur patches for Ivy Bridge-E?
For Catalina fix, is the #3 just a place holder? The FIND and REPLACE strings are identical.
Spayro
