macOS Catalina (10.15.x)
If you're using Clover as a bootloader, use the following patches:
Name*Find* [HEX]Replace* [HEX]Comment
com.apple.driver.AppleIntelCPUPowerManagementFF0F840F 01FF0F850F 01Power Management Patch #1
com.apple.driver.AppleIntelCPUPowerManagement0100010F 840100010F 85Power Management Patch #2
com.apple.driver.AppleIntelCPUPowerManagementC974140F 3225FF0F 00006BC974140F 3225FF0F 00006BPower Management Patch #3
com.apple.driver.AppleIntelCPUPowerManagementC974050F 3283E01F 4289443BC9EB050F 3283E01F 4289443BPower Management Patch #4
com.apple.driver.AppleIntelCPUPowerManagement01745D01EB5DPower Management Patch #5
com.apple.driver.AppleIntelCPUPowerManagement3E75383E9090Power Management Patch #6
com.apple.driver.AppleIntelCPUPowerManagement7511B9EB11B9Power Management Patch #7
These Patches worked flawlessly with my build. Thank you. I ran some bench marks afterwards and the patches improved the performance of the Z620 hackintosh build. Fantastic work!
Yes, it works like a charm.
Thanks for your help.
The link on x86PlatformPlugin.kext.for catalina is 404. Do you happen to have it around? (I'm testing this on big sur but I'm gessing it would work anyway).
The link has been fixed. That shouldn't work due to the change in kext. However, feel free to try and report.
Here we go.
(its name SSDT.aml in the ACPI folder)
Here we go.
Your SSDT doesn't have XCPM.
Pay attention to "HEDT" section.
Reactions: anibalin
Thanks a bunch mate! I have x86plugin finally loaded!
I was able to make de ssdt with version 16.7, otherwise, version 21.5 would get mad. Thing is that 16.7 does not have the cpus argument and I cannot address that I have 2 cpus as 21.5 does.
21.5:
Warning: No ACPI Processor declarations found in DSDT!
Using assumed Scope (\_SB) {}
Number of Scopes: 1
Error: Processor name(s) not found ...
Aborting ...
This is the 21.5 log with:
~/ssdtPRGen.sh -p 'E5-2670' -x 1 -target 0 -c 3 -cpus 2 -l 32 -mode custom -d 3
Thanks again!
  • SSDT.aml.zip
    SSDT.aml.zip
21.5:
Number of Scopes: 1
Aborting ...
Thanks again!
That''s a very common issue.
To fix it, follow the steps below.
Extract the ACPI set from your system.
Copy the SSDT1-cpu-def file and the apic.aml file to Desktop.
Rename the ssdt to dsdt.aml
Reactions: anibalin
zerockr
