Thank you , now it works!! but after sleep black screen , kernel panic and reboot. Im searching in google about problem and cant find solution. :(
For a Mobile CPU, the ACPI must be patched. Read here:
Before using HD 630 i use this hack with rx580 4gb and sleep work normal. I think problem with hd630 and HDMI audio
If you're using a Desktop, note that the sleep/wake function is broken since SKL on Desktops. HDMI Audio has several requirements.
Thanks. Yes i have a desktop with mobile 7700hq es mutant(its a mobile bga1440 soldered to lga1151v1 textolite). All desktops with 6,7,8,9,10-gen processors without discrete graphics have sleep troubles? :D
Yes, that's correct.
mulineee21
