Thank. You- Now everything is working but as I told you sometimes when the system boots, i have black screen. Is there a reason?
Did you added the missing drivers?
Attach your complete PR files. And make sure your BIOS settings are correct.
Hi again. I did add the missing drivers. All the files are there as you told me, the bios is correct i have confirm all the steps like in here, in the section BIOS setup. Is difficult to say there are PR files because i only see a black screen, I reboot and everything goes normal. At first glance is difficult to identify where the problem is, when this on disappears, and only returns may be on the 100th or more times i boot, that´s why it´s so odd. It´s a situation that is random could appear or not, but when this happens the screen goes black, but the computer is not freeze, because after reboot there is no error reported.
Try to change the display cable.
Hello. Yes it´s a cable problem. Happen today. I remove the cable inserted again and voilá it´s on, no error only something with the cable.
If i buy a AMD card I´m going to need a kext, or it´s working Out of the Box.
Yeah, NVIDIA is no longer joy.
Mark the thread "SOLVED"
Hello , if a have a ES sample proccessor on desktop what device id i need to inject (5912 for desktop hd630 or 591b for notebook processor)?
591B0000 is the one you need to use for Mobile CPU.
Refer to post #47
Thank you , now it works!! but after sleep black screen , kernel panic and reboot. Im searching in google about problem and cant find solution. :(
CIZART
