The installation is finish trying to load from the disk where i made the installation but i have this message [IGPU] Graphics driver failed to load: could not register with Framebuffer driver!
Ignore the error for now. If you're unable to boot into the system, use 0x12345678 in ig-platform-id to boot.
Incomplete PR files attached. Attach the whole EFI from your USB which is being used to boot and install.
Hello
Thanks for all in advanced. I should told something about my installation yesterday, but I had several problems booting using the HFSPlus.efi., I don´t now the reason why, but maybe because I have all my disks M.2. After changing the HFSPlus.efi and star using the VBoxHfs-64.efi. i finally got the system installing and booting. The systems, boots, i have confirmed that i can shutdown, also the sleep mode works. When the system boot i recevive the message i told yesterday, but after few seconds the system boots. I don´t have the acceleration, no transparency the system shows that i´m using Intel UHD Graphics 630, but only 18 MB of memory, I think i forgot to put the USBInjectAll.kext in the kext folder, but i think all USB are working (it´s really necessary to used?)
When you mentioned that "Incomplete PR files attached" what you mean i need to attach?
I send you the all EFI, when if´s possible for you tell me something the Hackintosh computer it´s my main production computer for work, when it´s not possible to use i work with a old MacBook pro, that is really old, and not a really good computer to work any more.
Do you think it´s better to used a dedicated GPU for the Hackintosh, and what type the new 5700 XT AMD (witch model), or should i wait for the new Radeons?
The zip file it´s a 7z zip file, i change the extension name.
Yes, it's necessary to use.
I already replied int he previous post.
The file is corrupt.
Of course if you're having such work or want a easy setup.
I have add the USBInjectAll.kext.
Now what should i do to have acceleration with UHD630?
It´s necessary to add something to the section Devices on Properties, like i have I have seen on many posts? or only some parameters on the section Graphics.
I´ll send again with a link for google drive it tells me that it´s to big.
Attach your PR files to check.
I have send you a link for the google drive to download the file with all EFI folder
What files i should send you for the problem reported (i think is what this means , PR files)
Is there a way to get wall the result of the -v parameter when the system boots?
I think i found it with the tool hackintool, I hope.
Hi again, i have read carefully all the instructions to send files.
I think i have almost everything working. The processor it´s not very hell detected I think, and sometimes the systems boots, everything seems okay, but the screen is black.
I want to send the folders files compressed has you said with all the files mentioned in this page, but he IOReg file produced it´s so big.
I have produced one with IOJones, other with IOreg, tell me if it´s okay!
Incomplete PR files attached. Kextcache output, IOReg, and kext folder is missing.
To make a copy of your IOReg, read here:
Here are some of the issues
  • EHC renames is not required for your system. Remove it.
  • change MEI to IMEI rename is missing. Add it.
  • CPU type is not required for your system. Remove CPU type.
  • Kernel Lapic is not selected. In my original guide, this is already added. Add it back.
  • Necessary drivers are missing from the drivers folder. Add it back as per the guide.
When i create a Ioreg the file as 28,7 Mb, to much to upload. Heaven zip has 8,2 Mb.
How i can produced the Kextcache output. Don´t know how!
The Kext are missing because the compressed folder was to big as I said before.
The folder drivers has 3 files, note the HFSPlus.efi, because my system didn´t boot with this one, as I told you before.
I´m sending ioreg and other files you ask , but i can´t add on the same zip the clover folder.
raymondleung416
