[SOLVED] Lenovo Z500 audio issue
Not required.
From the properties, the audio one, remove # from layout.
Yes, if you have completed DSDT and SSDT patching.
the layout ID patch is remaining
so you suggest I place current DSDT and SSDTs back or wait until enabling audio and doing that patch?
Complete your DSDT and SSDT patching and place it. Some hardware requires the ACPI before the Audio can work.
I did the steps mentioned to complete patching but no audio is available
should I change the layout ID in the DSDT patch and properties of Devices section of Clover Configurator?
Yes, the layout should be changed at three places.
config.plist>Devices>Audio
config.plist>Devices>Properties>PCI root for Audio
DSDT
in the DSDT patches it only have some layout IDs
how should I check anothers?
Just replace the ID. For example if you want to use layout ID=99, then edit 12 with 99. As simple as that ;)
Hi again
I tried all of the layout IDs but none of them enabled audio, what a golden chance :LOL:
What should I do now?
Hi again
You must be missing something then. Check for updates on the forum. Will check and provide you a solution.
hapaya666
