Okay.Yes, it is formatted as apfs and yes, it is booting quite well on another host.
No PR files attached. Please note that the files must be according to the guide. Once the configuration is tested well, you can switch to VirtualSMC.Yes I fixed configuration and it works fine now. Only apfs booting problem still persists. I mean 2 approaches. One based on smchelper.efi and fakesmc.kext you refer to me and another one based on virtualsmc.efi and virtualsmc.kext which I use in my configuration.
