[SOLVED] Lenovo IdeaPad Z500
Yes I downloaded on MacOS Catalina on VMWare and did every steps you said in it
thank you so much
it's installed now but I have some problems, it detects Intel HD4000, but Audio and Wireless aren't detected. I also have purchased a wifi dongle model Tp-Link TL-WN823N for use with Mac OS Mojave and it had a driver for Mojave but it doesn't install on Mac OS Catalina
how can I do with these problems? should I patch DSDT before everything?
thank you so much
You're welcome
Did you checked the FAQ? Audio needs to be configured. WiFi needs to be replaced.
Yes, macOS Catalina only supports 64-bit Apps and drivers. Check Chris111 work.
Patching DSDT is a postinstall task and it's required.
You're welcome
ok
he published two drivers :
which one should I use?
WYLDE983
