[SOLVED] Lenovo IdeaPad Z500
Clover doesn't creates any EFI partition. The Createinstallmedia command does. So, when you prepare the bootable USB, a EFI partition is already made. When installing Clover, Clover will just place the EFI folder in your EFI partition.
Make sure you're using the latest build of the Clover from the forum.
thanks very much, I could fix that problem
now when trying to boot from USB it stuck in the following line for about 20-30 minutes :
ApplePS2Controller: Notification consumer published: ApplePS2SynapticsTouchPad
then it shows multiple lines quickly and then restarts so I can't read them or take a picture.
how should I do to fix this?
Probably DVMT issue. What OS are you trying to install?
Attach your files to check.
Your EFI folder, excluding the themes folder.
ok, they're here :
EFI
sorry but it's 2.23mb and the forum's attach option said it's too large so I have to upload it there.
ok, they're here :
EFI
Yes, the server is migrated. Will be fixed soon.
The directories are not upto the mark.
I followed this link as you suggested before and I did them step by step
what is my fault?
what is my fault?
Check your drivers directory first.
It said :
8.Copy the additional drivers to: /EFI/Clover/drivers64UEFI
so I got confused because there is drivers directory and inside it, there is UEFI directory and all of the selected drivers are there, so I created one drivers64UEFI and one drivers64/UEFI what should I keep?
The new Clover has drivers/UEFI directory. The rest will remain same.
RoxonPL
