HP Pavilion G6 1250ej
Why do I need to attach PR files when I am just following your guide?
I got that error after typing "make" in the terminal
(The error popped up in the terminal and nothing compiled. The build folder is still empty. I even tried it on another Hackintosh and got the same error).
I already attached my PR files in #62 and they did not change since then.
Laptop: HP Pavilion G6-1250ej
CPU: Intel Core i3-2330M 2.20GHz.
Chipset: HM65.
Graphics: Intel HD Graphics 3000 and AMD Radeon 6760M (Disabled because of lower performance than the iGPU).
Resolution: 1366x768.
Bootloader: Clover (Legacy). (This laptop doesn't support UEFI).
Clover bootloader folder (without serial numbers) attached below.
And how are they even helping you tell me why the "make" command doesn't work?
You must reattach. For separate issues, create separate thread.
Wdym separate issue???
I named this thread “HP Pavilion G6 1250ej”.
I didn’t specify the issue.
What’s the problem with just telling me why it’s not compiling?
Until i get the files, how and what exactly are you doing, i cannot say for what reason it's not being compiled.
They are literally the same files.
I am not going to send them again for no reason.
And again, how are they even going to help you understand why the make command doesn’t work?
They are not even linked to it.
After 2 months of waiting, I finally got my new MacOS compatible wireless card, BUT turned out that this laptop does have a BIOS whitelist.
It just didn't trigger it for the other card I tried.
Is there any way to modify the BIOS to allow this card to work?
My new card is a BCM94352HMB and the old card is a BCM94313HMGB.
Here is the link to to download the latest BIOS for my laptop: https://support.hp.com/us-en/driver...odel/5189024/swItemId/ob-115746-2?sku=A5G63EA
ctrnofear
