HP Pavilion G6 1250ej
So, can you recommend a couple of WiFi+Bluetooth Mini PCIe cards?
(If you can, send the model names of ones that support 5GHz as well. I’ll choose one depending on the price and performance).
And there is not a lot of space in this Mini PCIe slot so I can’t fit bigger network cards.
Some HP laptops do have that whitelist.
Yeah, they do have.
Btw, the Broadcom one I asked you about was the one I have already. But I think that it’s not supported under MacOS.
No, already mentioned, not supported. Buy Broadcom BCM94352HMB, Half Mini PCIe.
I only suggest Broadcom BCM94352HMB, Half Mini PCIe.
Ok, I'll order it.
It will probably take a month until I get it.
Hey, do you know how to fix the sleep mode?
rn, When I press the sleep button (in MacOS), the screen turns black but the laptop keeps running and I can't wake it from sleep. If I want to get back to MacOS I have to power off the laptop (by holding the power button) and then turning it back on.
And when I am closing the lid, it doesn't put the laptop into sleep mode. Instead it just turns off the screen until I open the lid again.
Filopateer Amir
