Fix Intel UHD Graphics 620 (Whiskey Lake) on Laptop
An EliteMacx86 Exclusive Guide - This guide covers fixing of Intel UHD Graphics 620 (Whiskey Lake) on Laptop. By following this guide, you'll be able to achieve full QE/CI on your Hackintosh.
macOS supports a wide range of Intel HD Graphics (also referred to as iGPU) but some of them might not work out of the box, if you have not followed the config.plist creation guide.
Before you start with this guide, please know something about the performance. Graphics enhance the performance and helps to work smoothly. In macOS, full acceleration requires that both Quartz Extreme and Core Image (QE/CI) should work together.
Quartz Extreme and Core Image (QE/CI) should work together to enable full acceleration on macOS’s GUI. It utilizes the complete Graphics capabilities. In case if you haven’t enabled QE/CI on your graphic card, you won’t be able to use your macOS smoothly and there would be lots of lags and artifacts, graphic related issues and poor refresh rate. Also the dock would not be transparent. Therefore it is very important to ensure that your graphic is working with full QE/CI.
BIOS Setting
The BIOS settings has been provided in a separate thread. For more information on BIOS settings, refer to the thread linked below.
					www.elitemacx86.com
Config.plist
The config.plist file must be as per the guide.
For Clover:
1. Mount the EFI partition of your system drive.
2. Navigate to EFI\Clover and open your config.plist with Clover Configurator.
3. Navigate to Acpi tab and add the following patch in DSDT section of your config.plist.
For OpenCore:
					www.elitemacx86.com
					www.elitemacx86.com
Additional Note:
					www.elitemacx86.com
Restart your System
Now you should be able to get your Intel UHD Graphics 1536 MB will full QE/CI. And your Dock would be also transparent.
Problem Reporting
Details:
Credits :
| Graphics | Intel UHD Graphics 620 (Whiskey Lake) |
| Kexts | Original Graphics kexts in S/L/E |
| macOS Version | macOS Mojave 10.14.1 or later |
BIOS Setting
				BIOS/UEFI Settings for macOS (Intel/AMD)
BIOS/UEFI Settings for macOS (Intel/AMD) Most motherboards will work with only a few changes from Optimized Defaults. However, for some systems, you must change the settings for booting macOS and optimal performance.  Before you start making changes to your BIOS, ensure you're running the latest...
					www.elitemacx86.com
				Config.plist
For Clover:
	Properties Key: AAPL, ig-platform-id
Properties Value: 0900A53E
Value Type: DATA
	Properties Key: device-id
Properties Value: A53E0000
Value Type: DATA
4. Save your config.plist file.For OpenCore:
				GUIDE - How to Create OpenCore config.plist file for booting macOS on Intel Laptops
How to Create OpenCore config.plist file for booting macOS on Intel Laptops  An EliteMacx86 Exclusive Guide - This guide covers creation of config.plist for booting macOS on Intel Laptops for OpenCore as a bootloader.  Overview   The config.plist is a system configuration file for the Hackintosh...
					www.elitemacx86.com
- The config.plist must be according to the following guide.
 - You must use "config_HD615_620_630_640_650.plist"
				GUIDE - How to Boot macOS Installer on Laptops using Clover (UEFI/Legacy)
Booting macOS installer on laptops can be a challenge for the new users. This guide covers a complete step to boot the macOS installer on your Laptop using Clover bootloader. Those who are not using Clover, can update their configuration for clover and continue to use it. Clover is one of the...
					www.elitemacx86.com
				Additional Note:
- On some Laptops, after fixing the Graphics, you may result in a black screen. For more information, check the backlight guide here:
				GUIDE - How to Enable Backlight Control on Laptops [Clover/OpenCore]
How to Enable Backlight Control on Laptops [Clover/OpenCore]  This guide describes the implementation of backlight control on Laptops and AIO using Clover and OpenCore bootloader. By following this guide, you'll be able to enable backlight control on your Laptop and AIO. In addition, this will...
					www.elitemacx86.com
				Restart your System
Problem Reporting
Details:
- macOS version
 - Copy of IOReg
 - Kextcache output
- DPCIManager/Status
 - About This Mac
 - System Information/Graphics/Displays
- For Clover, compress EFI/Clover, exclude the themes folder.
 - For OpenCore, compress EFI/OC.
- Do not include complete EFI folder.
 - Put all files in a folder with your name, compress files as Zip and attach files using site attachments only.
 - Do not use any external links.
Credits :
