Compatibility graphic video
Asus h110m-c
i3-6100 with intel hd 530
Nvidia gt 730
15.x
Good morning everyone, I would like to know in general which video cards are currently compatible with opencore (latest version) and sonoma. I am about to update my hardware and since I currently have a non-compatible video card (if not to be patched) I would like to buy a fully compatible one. Thanks in advance.
Main: Gigabyte h370 d3h gsm
Intel i7-8700k with integrated Intel uhd 630
ram 16gb (a bank) g.skill
SSD crucial mx500
SSD crucial mx500
See here:
I bought a rx 580 8gb can you help me configure it on my sequoia?
There's nothing much to configure as it supported OOTB.
i installed the video card but the mac still detects my igpu my rx is nowhere to be found. not even OCLP detects the video card
What has OCLP to do here?
What's your hardware specs and what macOS version are you trying to install?
currently i have sequoia installed, opencore legacy patcher i use it to patch my wifi card.
my current configuration
mail h370m d3h gsm
i7-8700k
16gb ram
currently as smbios i use macpro7,1 the only one that works with igpu and dgpu
in the bios i have enabled the use of the display from pci1 now the video from my video card is visible but in the system info it shows me "4MB screen"
Okay, no problem.
mail h370m d3h gsm
i7-8700k
16gb ram
Attach your EFI and a copy of IOReg to check.
XChikuX
