Storage Compatibility for macOS
OK thanks .. here's the files...
Here are a few issues
Make the following changes to your config.plist:
- Remove SSDT-GPU-DISABLE.aml, SSDT-EC.aml and SSDT-USBX.aml. RX580 is a natively supported card and you don't need to disable it unless you have an unsupported GPU installed. Use SSDT-EC-USBX.aml from OpenCore package. Just make sure to change PCI0 to PC00 in the SSDT.
- Either remove SSDT-SBUS-MCHC.aml or the MC to MCHC rename. You shouldn't be using both together!
- Set ResizeAppleGpuBars to -1 and also disable it from your BIOS.
- Remove all entries from DeviceProperties section.
- Kexts loading order is not correct. Important Kexts should load first
- Remove MinKernel from Emulate section.
- Set KernelArch to Auto.
- Disable CustomSMBIOSGuid.
- Disable DisableRtcChecksum in Kernel section.
- Remove EnableTRIM Key from the NVRAM
- Remove dart=0 boot args.
- Add alcid=12 in boot args.
- Set UpdateSMBIOSMode to Create
well the SSDT-GPU-DISABLE.aml i made because i need to disable the other gpu card i have in my pc (RTX 4070).
also the kext and the driver order where i can find to do right?
also when u say remove all DeviceProperties section. you mean this red?
here's the new config list fixed after your check.
Then its good.
birds_rocks
