Audio Compatibility for macOS
Intel Smart Sound Technology (Intel SST)
Intel® Smart Sound Technology (Intel® SST) is an integrated audio DSP (Digital Signal Processor) built to handle audio, voice, and speech interactions. However, Laptops with Intel Smart Sound Technology (Intel SST) aren't supported on macOS. Any device connected through (usually a built-in mic) will not work under macOS.
Headphone/Combo Jack
Few Laptops with a Combo Headphone Jack may not get any audio input through them and you will have to either use the built-in microphone or an external audio input device via USB.
Supported Codecs
Not all Audio Codecs are supported by AppleALC on macOS. Refer to the Audio Codec Support linked below for more information
elitemacx86.com
Supported Codecs
Supported Audio Codecs List for OS X and macOS
Supported Audio Codecs List for OS X and macOS Audio Limitations and Compatibility Not every Audio Codec is supported by AppleALC on macOS. With some of the hardware, there are some limitations as well. Refer to the compatibility guide linked below for more information...
elitemacx86.com
LIMITATIONS
