GUIDE Intel HD Graphics 4200/4400/4600 on macOS 10.12.x and Later on Laptops [Clover/OpenCore]
Solved it.
Installed kext from RehabMan (with Kext Drop)
With PlistEdit PRO:
Devices-FakeID-IntelGFX-0x04128086
ADDED line to:
Graphics - ig-platform-id 0xa260006
Works OK for me with Niresh Mojave, RehabMan kexts, and this guide
Note that I didn't change GFX0 to iGPU in DSTD Patches. Didn't work well for me BUT it was all a bit of trial and error.
Thank You for this useful guide!
Solved it.
With PlistEdit PRO:
ADDED line to:
Good Job! :)
Please help, i have already followed all of your instructions, but it isn't working.. intel hd 4600 showing only 4mb, and it is glitching on some apps. i already attached the required files.
is my supplied information okay? i cannot find the way to obatain ioreg and kextcache information..
  • logitechmac efi clover folder.zip
The configuration is not as per the guide. Moreover, looks like you've installed Niresh Distro. Install Vanilla not distro.
I am sorry, I didn’t know that
So there is no way to fix this, rather than reinstall my hackintosh 😔😔
by the way,
thanks for the reply. Much app
by the way,
Yes, of course.
As per your profile, it looks like you have a Desktop. Is that correct?
Similar threads
lovos33
