Rx 570 pink screen
ssaaamuuu
gigabyte b460m ds3g
intel core i5 10400
rx 470 with rx570 vbios
12.x
Hi everyone, i’ve installed monterrey on my desktop and everything works perfectly when im using my uhd 630 igpu but when i use my rx 570, it works fine but the display looks with purple/pink colour. I attach a picture. Please let me know any solution. Im using DVI port because it is the only one that i have.
What's the GPU vendor?
Also, are you using DVI to DVI or DVI to HDMI/DP?
Not the poster, but I had the same case with DVI to DP cable
Setup is Ryzen 5 5600G with iGPU disabled and RX 570
Setup is Ryzen 5 5600G with iGPU disabled and RX 570 as a main display
Framebuffer patching might be required in that case.
I have the same problem, I have an RX 570 with a single DVI output and the screen image turns purple/pink, when I start the MacOS installation through the opencore boot, the colors appear normal, but when the installation starts the colors turn purple/pink. Did you manage to solve it?
Could you help me?
Could you help me?
Try DP/HDMI cable and then check. Ensure the connector type is being patched properly.
I believe it is the cable, because I use a DVI-d to HDMI adapter, my monitor is HDMI and my card only has DVI-d, I will check if I can find a different cable.
What vendor is the card? RX 570 does have DP and HDMI as well.
This was it: ASUS AMD Radeon RX580 8GB 2048SP GDDR5 Graphics Video Card (DVI Single Port), I bought it on eBay and where I live we don't have much financial resources to buy computer equipment, I didn't pay attention to the description and only saw that it had a single DVI output when the card arrived, after 30 days of transit.
The problem installing MacOS was the BIOS, the one on the card was modified, I installed the BIOS from the RX 570, because the 580 is not 2048SP and is not supported for MacOS
KsgNet
