GUIDE How to Fix Pink Screen on Intel HD and UHD Graphics on macOS Sierra and Later on Desktops [Clover/OpenCore]
First thing first. Boot using the connector type set as HDMI for the internal display. Does the AIO has any other external display output? Such as HDMI or DP or mDP or Type-C?
Yes I booted using the connector type set as HDMI for the internal display. Yes the AIO has other external display out. A DVI and a HDMI port
Great. Patch the connectors for the DVI and HDMI port. Check the display using those ports. Once you're done with that, use HiDPi script to fix the pink screen.
I was able to fix it with HiDPi, with correct monitor settings. Its working great, thanks a lot
I do not have an external display to check the other DVI and HDMI ports. All I have is the AIO display (which in Hackintool info section appears as: Internal=No)
Sounds good!
What was the main factor that caused pink screen which you were able to resolve?
Sounds good!
Framebuffer patch and connector settings were already correct. Since the HiDPi fixed the pink screen issue, so I guess it was the display monitor setting that was the main factor in resolving the issue.
Well, you were already told yo use the HiDPi script.
Reactions: Lenovo-M93Z-AIO
Nagres
